Story is started the car and let the fuel pump prime....then drove off...After 10 mins of driving the pump would eventually get a loud hizzing sound...
While revving the hizzing is loud but toleratable
but when i take my foot off the accelerate pedal to slow down or came to a complete stop, the hizzing sound would get really loud....
My fuel tank level is half way and i put bp ultimate...
Any one got any ideas?
PS. When a mate installed the fuel ppump it was running fine..Test drive it for 2 days then i stored the car for 6 months in the garage...6 months later started to use it today and all this happened.....
https://www.sau.com.au/forums/topic/292896-fuel-pump-nose/
Hey man, i had a real noisy buzzy fuel pump wen i bought my car ,heard it from the moment i put ignition on, got louder wen i accelerated, i thought it was aftermarket until i took it out to change it. does ur car take a while to crank?
my old one died on me, turned out to be a shitty stock one,,maybe u should check the wiring on it, but otherwise from wat ive heard, aftermarket ones are meant to be a bit loud..
but yeh, the one i installed in my car only buzzes wen i turn ignition on, and never again
https://www.sau.com.au/forums/topic/292896-fuel-pump-nose/#findComment-4892418
What pump did he install? Some aftermarket ones are rather loud, i have a Bosch 040 in my R33, and it is rather loud but i live with it.
https://www.sau.com.au/forums/topic/292896-fuel-pump-nose/#findComment-4892577
Benzimo - my car cranks fine..i just gotta wait for the priming to finish which only takes 5 secs
I can live with the noise but i just wanna know if the fuel pumps are meant to have a loud buzzing sound when accelerating and on idle...
Aberax - Its a bosch 023 (big bro of 040 i think)
https://www.sau.com.au/forums/topic/292896-fuel-pump-nose/#findComment-4892769
I think its alright man, bigger pumps will make noise, just live with it, but if it aint broke, dont fix it
https://www.sau.com.au/forums/topic/292896-fuel-pump-nose/#findComment-4893281
My Walbro makes a similar noise, kind of like that noise your speakers make when they are not hooked up properly. Got really worried because I thought the Walbros were rather quite. Went to my tuner and all good just noisy, you get used to it.
Just turn the radio up louder to drown it out...hehe
https://www.sau.com.au/forums/topic/292896-fuel-pump-nose/#findComment-4893514
