  • Replies 180
  • 3 months later...
  • 1 month later...
I'd be tempted to say an Evo VI or something but I've gone off them lately...they are a bit too 'try hard'.
FKN ROFL!
EVO VI for me under 20k, had one, loved it... Would definitely get another one, would like to know how they're 'try hard''...
FKN ROFL!
It's a FWD with a rear diff tacked on..
  • 5 months later...
i'd find a klze(j-spec version of klde in 626/telstar/probe/mx6)put it in my telstar.add turbo,looks good,sounds freakin awesome,despite torque-steer city,would move like a commo driver on iq test days and be great to put to shame many cars that cost ten times as much and more.check out klze action on youtube.anyone got a spare klze lying around?oh and it has less body roll than my r ,sounds better,but no, you guessed it,quite SLOOOOOW in comparison.yuk yuk.
dattos arent nissans so.............
all out : slice up a datto 1200 coupe to fit a 3.4 stroker twin gtrs turbod rb26
retro coolness: devil z or a gtr clone [kpgc10]
practical : e30 318 with a m3 kit and 6cylender 6 speed/ earliest evo i can / forester with sti swap / xr8 engine wagon
luxo : soarer with a v8 and a auto in leather or a bmw.
cause i can : see my posts in the how would you build a sleeper thread [pg 8] and a gtho phase 4 clone.
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
    • With that engine being a one rotor, would that make this into an RX4?
