Hi everyone, I've just moved here, I'm in need of a workshop to diagnose where I have this squeal coming from under boost (3/4 throttle).
I spose its one of those things that could be found very quickly on a dyno, has anyone got a recommendation on a decent shop that won't charge the earth for what is more then likely a simple task with the right tools. I live in the city if thats anything to go by, anywhere close to there/airport area.
Thanks
https://www.sau.com.au/forums/topic/292930-need-a-workshop/
Guest
