  • Replies 95
I'll sell u my 34 rims for $450 with tyres :thumbsup:
3 outa 4 centre caps tho and tyres are very legal and been through regency fine.
You talking about these rims that i borrowed? They look ok without the centre caps.
Huge thanx for the rims Luke, I can now stop boring my girlfriend with all the dif sizes and prices I keep seeing online and wishing I had :)
In true Awsam fashion though, and further proof even the simplest of things with cars for me are made difficult..
My jack handle snapped while putting the rims on, so my skyline is now stuck suspended until a mate cbf'd comming over with theirs lol
use your spare jack that should be in your boot.
ive done the same thing not to long ago with my sil.
Spare jack.. tick
jack handle... um.. where? lol
Doesn't matter now anyway, got a 4WD hydrolic lifter to put them on. Doesn't matter which R34 rim i put on the front, they scrape my calapers. Makes a disgusting clunking noise and messes with my steering real bad. The calaper has left a perfectly straight groove in the rim *sigh..
I'm about done with this skyline, all the simple things i've had done to it have turned into absolute nightmares, this car has me completely exhausted and I think the next thing that goes wrong I'm just gonna get rid of it and go back to driving my Calibra.
They hit the caliper? they cleared my brembo's and chad's stag. Thats odd.
Yeh was one rough ride man, I posted a thread about my problem. Maybe I have different calipers than I'm supposed to???
Maybe there's something wrong with my suspension, the front drivers side is a little spongey, and the tyer on the R34 rim seems to be touching the arm bit above the wheel very slightly every now and then.
thread has pics of the calipers, will post a pic of the groove left in the rim aswell
http://www.skylinesaustralia.com/forums/R3...-C-t296066.html
Edited by awsam
Hard to tell from the pic. I'll see if I've got a small spacer for you to fix it rubbing.
I've got a set of 5mm slip on spacers that luke removed off my car a few months ago that u can have for $20 if u like?
-D
-D
How's the vibration with a spacer on the front? I was going to take an angle grinder to the caliper and shave a couple of mil off LOL! f**kin take that!
This thread has the pic of the actual front caliper
My calibra has similar looking Calipers to the rear ones pictures in that thread, but on all 4. I thought maybe my 33 was supposed to have the same style rear ones all the way around also..
Edited by awsam
I didnt know the spacers were on all 4 wheels when I bought it, and tbh I didnt notice a difference when they were off, so I can say confidently that if you bolt your wheels up tight, it wont be an issue :happy:
-D
-D
Hrmn I think I'm prob just going to have to do that. Will i need to put all 4 on? Rears sit perfect as is. Are spacers illegal in SA?
yeah, both slip on and hub centric ones are illegal but paint them black and itll be harder to see.
also, depending how big of slip on spacer your get i would look into getting longer wheel studs but thats just me.
and if you use hub centric ones, get lock tight glue stuff that can be found at any car place like autobarn along with slip on spacers
hub spacers can be bought at wheelworx if your wanting them.
luke, remeber taking my 34 rims off my 33. they have some decent sized hub centric spacers on there to clear the brakes.
34 rims will also need spacers on a 32
are slip on spacers illegal? my car passed regency with em both times. never even got mentioned whilst in there.
To glue the spacer to the rim?
you use the lock tight on the bolts in the hubcentric spacers to make sure they dont come undone. they come with a different set of bolts. dont use hubcentric spacers with the 34 rims its not neccessary with the 34 rims as 5mm spacers will do the trick
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
