does anyone has a NISMO "3 INCH FROM CAT BACK 5 INCH CARBON FIBRE TIP" Exhaust? the model number is 20100-RN591. i wanted to know whether it is EPA legal and it has any drone to it? my R33 is stock standard. planning to buy it second hand. i m after an exhaust which sounds a bit more than stock.
attaching a few pics as well.
https://www.sau.com.au/forums/topic/292940-nismo-exhaust/
Hi Mate,
I've the same exhaust on my R, and it's a very quite exhaust. It will easily come in under 90db, but if you plan on going for more than 320rwkw, this aren't the exhaust for you (i found this out the hard way).
https://www.sau.com.au/forums/topic/292940-nismo-exhaust/#findComment-4892966
I have one of these, it is a bell mouthed tip so dont expect it to be quiet, I was EPAd with mine, but hey they look good! :)
https://www.sau.com.au/forums/topic/292940-nismo-exhaust/#findComment-4893222
thanx man. what happened with ur EPA? how did u rectify it? are these really loud- like my neighbors r gonna kill me :thumbsup: ?
my car is gtst auto.
https://www.sau.com.au/forums/topic/292940-nismo-exhaust/#findComment-4893256
Auto's do tend to be a little louder driving around.
However it is 3", has two mufflers that are of moderate size... it shouldn't be too far off legal, but not terribly loud at the same time. I suspect it would still be over 90dB however (if you are Vic)
Just keep your stock exhaust and swap over should you be pinned.
The EPA laws are so flawed in their design, application and archaic in nature that it's just easier to keep the stocker and swap back.
If you get 3 EPA's for exhaust noise you will be hauled in for a full test. Also if Police/EPA stations take photo's of the aftermarket exhaust, and you rockup with a stock one, things might become difficult after a while.
But look, you should be right. I've had more EPA's than i've had speeding fines and defects put together... and im still going strong because @ the end of the day, the Police can report you to the EPA without proof or even hearing the car, so if it ever goes to court over a suspension it will fall over.
Hi Mate,
Did you actually have to go through a test to confirm?
90dB @ 5100rpm is VERY quiet, so quiet the factory exhaust barely passes :)
But ye basic rule
3" = upto 300rwkw.
3.5" = 300-400rwkw
4" = 400rwkw+
https://www.sau.com.au/forums/topic/292940-nismo-exhaust/#findComment-4893450
I have a stock exhaust system for this reason, it only just passes EPA test. the windows rattle with the nizmo exhaust so im told. :)
https://www.sau.com.au/forums/topic/292940-nismo-exhaust/#findComment-4893688
But ye basic rule
3" = upto 300rwkw.
3.5" = 300-400rwkw
4" = 400rwkw+
You might have a point there, i was more going by feel. My old gtst went through the test, and it came upto 91db, whereas this seems a lot quieter. Than again the revs they test the gts and gtr are different.
Another point to keep in mind is, the older the exhaust gets, the louder it starts to sound(not by much, but it does generally get louder)
https://www.sau.com.au/forums/topic/292940-nismo-exhaust/#findComment-4895041
  • 5 months later...
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
