hey guys, have a r32 gtr rb26 block, which was previously bored out to 87mm and somehow the people that did the job left scoring in the bores... not sure if it would be as simple as a hone and replace the pistons (havn't really looked at it properly)... has new welch plugs, and overall in good condition, would guess it would only suit being sleeved, or risking the larger bore pistons... also has cradle to match... chasing $500
r32 gtr sump and diff, great condition... $450
rb26 baffle plates (the ones that bolt to the cradle) ... good condition $80
rb26 standard harmonic balancer good condition ... $80
rb26 standard rods, great condition, have 12 ... $150 for 6
r32 gtr crankshaft, (the early one with the short oil drive, also has some scoring on 1 rod journal) ... $100
rb26 crank, unsure what model it is, will take the oil pump off and have a look ... $depends
rb26 standard pistons and rings, reasonable condition, handy for some spares... $50
r32 gtr engine mounts, the metal brackets which bolt up to the block and the mounts... $100
located on the far north coast NSW, we will combine items at a lower price too. can deliver personally as far as brisbane qld, at a little extra cost... cheers ... pics will be posted up here upon genuine intrest requests...
please pm us if you are interested...
UPDATE AND REVISED PRICES...
hey guys, we have most bottom end parts available, all in good condition. block has some serious scoring in 3 cylinders, the other three are perfect... its at 87mm bore, would suit being sleeved, and possibly risking a larger bore (its been done)... its from a early model r32 gtr, so supposedly the tougher 05U block, will come as seen in pictures, with all oil squirters in new condition (only replaced a few thousand K's ago), as with the welch plugs... all journals are in top condition too.... and will come with the cradle that match's the block, ... chasing $500 for the block
post-56395-12561743833347_thumb.jpgpost-56395-12561744305443_thumb.jpgpost-56395-12561746141149_thumb.jpgpost-56395-12561746466433_thumb.jpgpost-56395-12561746781877_thumb.jpgpost-56395-12561747487653_thumb.jpgpost-56395-12561748159392_thumb.jpgpost-56395-12561748682554_thumb.jpgpost-56395-12561749258883_thumb.jpgpost-56395-12561753398481_thumb.jpg
R32 GTR rb26 crankshaft (in great condition, no marks on any of the bearing surfaces), it is the one with the shorter oil drive though (easily fixed with a aftermarket collar-$100) chasing $400
post-56395-12561750119618_thumb.jpgpost-56395-12561750619107_thumb.jpgpost-56395-12561751406003_thumb.jpgpost-56395-12561751760837_thumb.jpg
R32 GTR rb26 crankshaft, same model as above (great condition apart from the one rod journal, easily machined, which has slight scoring on it) chasing $200
post-56395-12561757491241_thumb.jpgpost-56395-12561757778797_thumb.jpgpost-56395-12561758192935_thumb.jpgpost-56395-12561758609798_thumb.jpgpost-56395-12561758844734_thumb.jpg
R32 GTR rb26 standard rods, great condition and nearly the best standard rods in the world... $150 for 6 (have 2 sets)
R32 GTR rb26 standard pistons (86mm) average condition, pitting in the quench area's $50
Rb26 87mm pistons (not sure of brand) 3 are great, 3 are crap... $150 (pic shows the 3 good ones, with the standard rods)
R32 GTR standard harmonic balancer (great condition) $100
RB26 tension and idler pulleys (only a few thousand k's old) still spin very freely ... $120
Rb26 knock sensor and plug, (have misplaced the other so only the one for now...) $70
RB26 engine oil baffle plates (good condition) $80
Rb26 sump, great condition, with baffle and diff... $550
  • 3 weeks later...
bump, found the other knock sensor... have all other engine accessories... please let us know if there is anything you are after?
cheers
  • 3 weeks later...
  • 3 weeks later...
hey guys, need to move some gear out... taking offers, if you have anything aftermarket for an r32 gtr (engine, interior anything), we can organise something... cheers
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
