thanks for the vote doof, where do i send bribe lol.
Entry form and cheque in the mail, had to do it the old fashioned way.
Gotta tell ya, your car would be a contender for best engineering award! :P
  • Replies 319
Posted Images
hey guys i want to enter my r34 gt-t which is not heavily modded so it's nothing serious for me
do i have to set up my own stall if mine isn't 'show' car level... or will i jst have spot to park my car in the show, no hassles kinda thing
cheers
seriously, it's no hassles awesomness :)
There's no awards for best display or anything like that. You CAN set something up if you feel like it, but I dare say most of the entrants won't be bothering :)
This is pretty hardcore car/skyline appreciation, at its finest!
I can't stress enough how much someone with just a mildly modded car has to gain from entering. Imagine 100 or more other models of your car, with all the mods you could ever want to do to your own, and having 100 or more owners to talk them about it and learn all that you'll need to know :)
couple questions guys, 2 of my mates want to come along and enter, one has a black s2k, and one has a modded mx5 (out of the 3 his car has the most mods), will this be cool? they are apprehensive as they have non-nissans
secondly, if they enter, is their a way to set it up so that we get 3 spots next to each other seeing as we are mates and we'll wanna hang out most of the day together?
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
