Show N Shine 2009 Entries Thread!
Duncan
  • Replies 319
Posted Images
got yours a couple of time stilo :D
guys no real need to confirm entries, we will shortly post up a list of forms and monies received for everyone to check.
HA! yer we got a new fax at work and none of us know how to use it :)
Edited by ST1LO
Entrant name - Forum Name
Mitch Smith - Mitch Rona
Stan Choi - Satanic
David Milane - Aggroman
Shant Nazarian - Shant
Thomas Bellas - GT-R LM
jeff Cook - Snoopy
Rami Sadi - Batakr33
Genelle Bill - Humbla
David Whitbread -
Keith Reid - Buddahlicious
David English - AVQR31
Bojan Terzic - 08R3308
Brendon Mitchell - ST1LO
Mitchell King - Mr Moo
Brent - ILLITE
Tai Nguyen - Mr Cali
Shanil Lal - SHANE666
Albert Yin - Sheng
Mitch Smith - Mitch_Rona
Robert Krstevski - Star32
Peter Krstevski - Star32
Mauro DiCarlo - 4SHOWZ
Andrew Livermore - EDS33T
Owen Hoogvliet - CPD
Terry Tung-Yep - Terry_GT-R34
Cameron - Cam84
Paul Mouhayet - Superjet760
Matt Tang-Yep
Desmond Siregar - Batakr33
Adam Zitka - MXHEVN
Nick Schembla -
Sean Armstrong - HOT_R33
Norman Chouaifaity - mr 32
David Andrew - Dave R31
Mark Seguna - BLISTIC
Stuart Gatt - BezerkR32
Elliot Dollisson - Runnin4Life
Vu Tran - Vudoo
Luke and Kace Hulks -
Drew Withey - Lanky71
Andrew Hempsall - Qantas
Jada Kenny - DV.11.SH
Sorry for eny spelling errors.
Please note, this isn't a complete entrants list. It doesn't contain any invited cars, any trader cars, a bunch of people that got their forms in first and there is still 2 weeks to get entries in.
meh Spelling mistakes and iknow i dont have the best hand writing but where did you get Thomas from ? :P
hey they both start with "T" :D
Thanks Shant...we are very much an "amateur" show compared to the Autosalons of the world, but the committee have been working their arses off getting a great location, great feature cars, great sponsors and a long entry list. I reckon the guys are doing a great job considering its a second job!
We still have heaps of space available for cars and want to make this show HUGE! If you thought about coming along but don't think your car is special enough.....ENTER! This is a club event not a global domination and its all about participation :D
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
