  • Replies 319
Posted Images
mine went with my membership paperwork. dont know if it went to duncan or liz. can we confirm
well if it went to Liz you are shit out of luck cos she has nothing to do with the sns lol..
That's what happens while you try to copy down all the names in the middle of a meeting while still giving up your 2 cents...
hahahah Just count yourself lucky i didnt give you my full greek first name. lol
All you guys have done a great job so far with an entry list already that large, big well done :D
Hi Duncan ... sent through fax with entry details that you should have & money via electronic transfer that will show by tuesday ... cheers Malcolm :)
Hi Duncan ... internet transfer completed this morning at 1015 ... cheers malcolm :P
any 1 know when the next batch of membership stuff is being sent out by the way????? been waiting abit
PM Shell. though, it should be soon as everything needed for the packs has been received recently or is on its way
I agree with Slim, it will (should) be very soon as we were waiting on SAU:Vic (blame game! :D) to send us 200 lanyards... Apparently they brought in an exchange rate too cause we only got 150 ;)
I faxed Both off to the number on the forms. which were both the same i think. should i fax the form off to another number than ?? if so which number. the money is in the account as my memebership has been put through.
Newcastle/Central Coast people: should we cruise together from F3 servos or something????
:(:D HELL YES WE SHOULD :banana::banana:
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
