Ok guys recently had new turbo put on and tune on 13psi makng 240kw's and loving it, the other day I was just cruising in 4th, then (for whatever circumstance) dropped into 2nd and flattened it. After this looked in my rear view mirror and there was a massive puff of black smoke, and driving seemed to bit flat... long story short, it now doesn't seem to be making much boost. It still spools and I can feel it start to pull but after hitting 4k it kind of just flattens off and has NO top end power.
So, doing a bit of research on this forum some guys have complained of melting metal cats so took that off and had a look and doesn't seem to be 'melted' at all so I'm assuming it's not that. Also had a look at all intercooler pipes and doesn't seem to be any cracks or loose fittings.
Could this be a spark issue? Coilpacks?
I understand black smoke is overfuelling problem, but has only happened that one time and has not been smoking at all since... and having an aftermarkt ecu I would assume the tune would take care of and r n r issues. Also like to add that exhaust note has changed, seems a LOT quieter than previously.
Really starting to upset me, any help appreciated!
Edited by SLEEPR85
https://www.sau.com.au/forums/topic/292968-r34-down-on-power/
Well it was idling a bit rough last night, not violently shaking or anything just a bit rougher than usual, was enough for me to notice. Driving between idle and 3k seems a bit sluggish also before the boost comes on, then it kinda of spools and doesn't really convert into power....
How does it free rev does it feel normal? If it doesnt take the cat off again and give it a rev to be sure it is a blockage in the exhaust. It will be LOUD. You could drive it up the street but you might get locked up. How much boost is it getting up to and is it blowing any black smoke anymore. What ecu is it and can you check the sensor inputs especially coolant temp incase somthing has gone wrong and its seeing very cold will make it rich.
Revs feel a bit choked, that's why i thought it was the cat.... not blowing black smoke anymore, just that one time. Running emanage ultimate ecu, still boosts to over 10psi but haven't really fully booted it. Where would these sensor inputs be?
Was speaking to a mate of mine who has owned and built a few skylines and he suggested that the front compressor of my 2835gt may had let go, does this seem likely? Still boosts but sounds like its sinning twice as hard to get half the power i was getting....
Took the pipe off from the turbo to the intercooler to see if there was any oil leaking anywhere but didn't feel anything. Apart from taking the front intake off the turbo to get to the front compressor (which is surprisingly hard to get to) is there any easy way to know if the turbs is blown or not?
Hows it going? Have you sorted it out yet? Most aftermarket ecu's have some kind of sensor check or data readout. i dont know about emanage though.
other than buckets of grey (oil) smoke coming out the or bad noises the only way to check your compressor wheel is to get your fingers to it and check for play. if they do let go its prob best to check it. You dont want it in your engine.
Let us know what yo find
  • 3 weeks later...
Ok an update for anyone's future reference.
Took it to my mechanic, said really couldn't fault it in many ways, except when he looked at the sparkies they seemed to be white which would mean that my engine is running lean... suggested i put it on the dyno for a more accurate reading of afr's, etc.
Ended up being injectors were set close to 100% duty cycle and was causing them to cut out at high revs, so my tuner said he dropped it and lowered boost by 1psi down to 12psi.... which still made the same kw's as at 13psi....
Now the question i have now is why would they just start doing that all of a sudden? Do they have a default "safe mode" that when they hit 100% they automatically go back to standard? Think its upgraded fpr time!
more likely boost cut. The emanage does not care whether its in the high or low octane map.
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
