Hi All,
As title suggests - car has been fine, no probs with anything then suddenly key got stuck in ignition barrel. Can turn the car on and move key forward and back just cannot release the key, have tried moving steering wheel around and jiggling key (for nearly 2 hours!!) before i stopped before i snapped something. I have been reading through heaps of material and I'm reaching a point where i might have to go to a locksmith but can't really afford to do so. My car was an auto to manual conversion and i was reading something about the car not knowing its in 'park' not sure if this is the problem or how to tackle it but any info appreciated. I am hoping it is just a loose wire of some sort that is locking the key in, kinda makes sense but at this stage my car can't be locked and the doors are open with the key in the ignition - i have taken off battery lead for time being but don't wanna leave it like that for more than a night.
Cheers guys
-Steve
https://www.sau.com.au/forums/topic/292984-sighs/
I disbled the "Door open charm" and that alarm is brought on by a switch that the key slides along. I'm thinking somehow maybe this switch is lachted on and stuck on the key inside the barrel.
look on the tutorials page for info on disabling the charm. It's just a matter of taking the plastic around the ignition barrel off and having a look under it. might be worth a go...
https://www.sau.com.au/forums/topic/292984-sighs/#findComment-4893542
Thanks heaps random, i took off the the plastic around the ignition barrel and played around a bit, then i reversed the car about half a meter and the key came straight out. Not sure which one actually fixed it but appreciate your help, i was starting to panic a bit - if anybody else has the problem in an auto to manual conversion try moving the car forward or back, as dumb as that sounds i think that's what may of fixed my problem (or that and a combination of 'playing around' with the ignition.
-Steve
https://www.sau.com.au/forums/topic/292984-sighs/#findComment-4893990
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
