i have JUST finished installing my plenum. i just need the throttle cable shortened and im done.
some things that are still fresh in my mind:
- as soon as you get it, take it to a machinist to flatten ALL surfaces on it. it gave me peace of mind doing mine and i know its plumbed up perfectly with the head.
- buy some 2.75" silicon hoses and bends (stock size) as well as some super clamps. comes in handy when cutting up pipes to fit the new cooler rout.
- test fit the BOLTS into the holes of the plenum and check if there is enough clearance for a socket to fit and tighten the bolts all the way in, i had 1 of them get really tight, it was a pain in the ass to cover everything up and start grinding while it was installed on the car.
- if you want to re-use your gasket for whatever reason - make sure its not distorted. if it is it wont let your bolts through and meet with the head. take the gasket and fit it to the plenum while its off and bend it so that its straight and meets with the bolts with no distortion.
what i did to make my install easyer was fit a few longer bolts into the head first so i could slide the plenum in and out so i could guide some bolts through the gasket and into the head. i put 2 long bolts in (one on each end) and i put the other bolts on lightly so that they had JUST started on the threads then when i had most of them through the gasket and in the head i tightend them up and replace the long bolts with proper sized ones.
what happens is you put your gasket in, it sits on the 2 studs already there and the middle bends down so when you stick your bolts in afterwards the gasket gets in the way.
- top radiator hose: just flip it around and it will fit straight on.
- get some decent small clamps for things like your fuel system (dont use the ones they give you).
- just before fitting my plenum i put all the plugs that go into the bottom in first by holding it up near the plug. its a P.I.T.A. doing it while the plenum is already on, especially when the black/blue plug has a hose that runs RIGHT next to it.
- get some decent tools, i used all of my socket sets (1/4, 3/8 and 1/2 inch). also get some ramps or car stands. ramps are #1 in my book.
- when you get your AAC valve fitting welded to your cooler pipe, get them to tap or weld a vacuum hose fitting to the turbo side so youve got a nipple on that side of the engine bay for a boost controller.
be patient, always think of your next step before you start something, start early in the day and have some beer and smokes handy and a shitload of band aids.
p.s. i have a china greddy copy on mine and i had it sanded down and powder coated by Chris from Craved Coatings and he told/showed me it had a shitload of bog in it which he replaced with some kind of alloy weld - so be warned. if you dont get it treated you risk it cracking and come off in the future which may cause air leaks.
Got any pic's??
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
