This is a pretty sensitive topic so I cant say much, but basically my recommendation is if you dont know what your doing dont get one. Me an my cousin have both been using RD's for awhile now, first time using one in a place sooooo illegal, there are products I DO recommend but for 140 your not going to get ANYTHING good especially since they will be detected by the cops and you'll get raped.
I like your input mate...
hahaha. Enough said.
they can pretty much ransack your car if they think you have one cant they?
Yep, as far as I know.
My off the record advice...if you buy one be willing to lose it. You might want to practice buying a couple and smashing them on the ground because that's what you'll have to do in 2 seconds if you ever see a cop give chase after detecting it.
I used to have one of these...the real deal ones cost a few hundred and you need to buy them from America. These will beep at service station automatic doors while you drive along the highway, and scream bloody murder if someone has a radar lock on you. Plenty of cops locked radar on me and they never detected my unit. But I kept it underneath a towel on the dash (cause you're just a f**kin idiot if you go showing it off like a G-tech), nearby and ready to throw out the window if I saw a cop get in his car or pull out on me. As illegal as they are, I don't believe they should be...they do the job that the cops should be doing, i.e. deterring speed instead of extracting revenue from it. If they put fake radars everywhere these people wouldn't speed...but the government wouldn't get cash :(
Can cops detect your car with a Radar Detector in it?
DO they have a detector to detect the detector..?
LOL!
As funny as this is, yes :(
And believe it or not people have come up with detectors to reveal their radar detector detectors. It stretches that far. As long as there is an infrared beam going out it can be detected!
Reminds me of that movie "The Big Hit". The trace buster buster buster!
LOL!
Heck yes the do I'm pretty sure not all coppers are fitted with them but RDD's do exsist if you really want to 1-up them you can get a Radar Detector Detector Detector (RDDD) which will detect them trying to detect you.... I know it's confusing but there is a whole world of Radar Detection if your really intrested i recommended www.radardetector.net
They have probably all the info you need but with top of the line products (which you should be able to find with a couple Google clicks) you shouldnt have to worry about detection, also FYI if you do end up searching and comparing products Beltronics IS Escort, escort acquired them in 2000 they are known as Belscort by enthusiasts
The only radar/laser detector which is tested as undetectable by "radar detector detectors" used by police is the Beltronics STi / STi XR. I used to have one, but got over it and sold it. Top unit. The valentine one sometimes has more range and a cool directional "bogie" counter system, but it's detectable by RDD's.
check out http://www.delonixradar.com.au/radar-detectors/tests/
last i heard they have detector detectors, and if they think you have one in your car GL.
As funny as this is, yes :P
Yeah, interesting points there fellas.
Ah well, stick to the speed limit and you'd be fine :devil:
I have been searching this alot and I can't tell you the actual penalty as it's a summons to court offence so it's up to the Magistrate as to what penalty you will get. I have found that it's offence to possess, use, sell or own a device under Road Safety Act 127/1986 Section 74 (1).
Hope this helps and obviously they can be detected and vehicle searched for same and if located should be seized for court and eventually disposed of.
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that green thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
