This is a pretty sensitive topic so I cant say much, but basically my recommendation is if you dont know what your doing dont get one. Me an my cousin have both been using RD's for awhile now, first time using one in a place sooooo illegal, there are products I DO recommend but for 140 your not going to get ANYTHING good especially since they will be detected by the cops and you'll get raped.
I like your input mate...
hahaha. Enough said.
they can pretty much ransack your car if they think you have one cant they?
Yep, as far as I know.
My off the record advice...if you buy one be willing to lose it. You might want to practice buying a couple and smashing them on the ground because that's what you'll have to do in 2 seconds if you ever see a cop give chase after detecting it.
I used to have one of these...the real deal ones cost a few hundred and you need to buy them from America. These will beep at service station automatic doors while you drive along the highway, and scream bloody murder if someone has a radar lock on you. Plenty of cops locked radar on me and they never detected my unit. But I kept it underneath a towel on the dash (cause you're just a f**kin idiot if you go showing it off like a G-tech), nearby and ready to throw out the window if I saw a cop get in his car or pull out on me. As illegal as they are, I don't believe they should be...they do the job that the cops should be doing, i.e. deterring speed instead of extracting revenue from it. If they put fake radars everywhere these people wouldn't speed...but the government wouldn't get cash :(
Can cops detect your car with a Radar Detector in it?
DO they have a detector to detect the detector..?
LOL!
As funny as this is, yes :(
And believe it or not people have come up with detectors to reveal their radar detector detectors. It stretches that far. As long as there is an infrared beam going out it can be detected!
Reminds me of that movie "The Big Hit". The trace buster buster buster!
LOL!
Heck yes the do I'm pretty sure not all coppers are fitted with them but RDD's do exsist if you really want to 1-up them you can get a Radar Detector Detector Detector (RDDD) which will detect them trying to detect you.... I know it's confusing but there is a whole world of Radar Detection if your really intrested i recommended www.radardetector.net
They have probably all the info you need but with top of the line products (which you should be able to find with a couple Google clicks) you shouldnt have to worry about detection, also FYI if you do end up searching and comparing products Beltronics IS Escort, escort acquired them in 2000 they are known as Belscort by enthusiasts
The only radar/laser detector which is tested as undetectable by "radar detector detectors" used by police is the Beltronics STi / STi XR. I used to have one, but got over it and sold it. Top unit. The valentine one sometimes has more range and a cool directional "bogie" counter system, but it's detectable by RDD's.
check out http://www.delonixradar.com.au/radar-detectors/tests/
last i heard they have detector detectors, and if they think you have one in your car GL.
As funny as this is, yes :P
Yeah, interesting points there fellas.
Ah well, stick to the speed limit and you'd be fine :devil:
I have been searching this alot and I can't tell you the actual penalty as it's a summons to court offence so it's up to the Magistrate as to what penalty you will get. I have found that it's offence to possess, use, sell or own a device under Road Safety Act 127/1986 Section 74 (1).
Hope this helps and obviously they can be detected and vehicle searched for same and if located should be seized for court and eventually disposed of.
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
