This is a pretty sensitive topic so I cant say much, but basically my recommendation is if you dont know what your doing dont get one. Me an my cousin have both been using RD's for awhile now, first time using one in a place sooooo illegal, there are products I DO recommend but for 140 your not going to get ANYTHING good especially since they will be detected by the cops and you'll get raped.
I like your input mate...
hahaha. Enough said.
they can pretty much ransack your car if they think you have one cant they?
Yep, as far as I know.
My off the record advice...if you buy one be willing to lose it. You might want to practice buying a couple and smashing them on the ground because that's what you'll have to do in 2 seconds if you ever see a cop give chase after detecting it.
I used to have one of these...the real deal ones cost a few hundred and you need to buy them from America. These will beep at service station automatic doors while you drive along the highway, and scream bloody murder if someone has a radar lock on you. Plenty of cops locked radar on me and they never detected my unit. But I kept it underneath a towel on the dash (cause you're just a f**kin idiot if you go showing it off like a G-tech), nearby and ready to throw out the window if I saw a cop get in his car or pull out on me. As illegal as they are, I don't believe they should be...they do the job that the cops should be doing, i.e. deterring speed instead of extracting revenue from it. If they put fake radars everywhere these people wouldn't speed...but the government wouldn't get cash :(
Can cops detect your car with a Radar Detector in it?
DO they have a detector to detect the detector..?
LOL!
As funny as this is, yes :(
And believe it or not people have come up with detectors to reveal their radar detector detectors. It stretches that far. As long as there is an infrared beam going out it can be detected!
Reminds me of that movie "The Big Hit". The trace buster buster buster!
LOL!
Heck yes the do I'm pretty sure not all coppers are fitted with them but RDD's do exsist if you really want to 1-up them you can get a Radar Detector Detector Detector (RDDD) which will detect them trying to detect you.... I know it's confusing but there is a whole world of Radar Detection if your really intrested i recommended www.radardetector.net
They have probably all the info you need but with top of the line products (which you should be able to find with a couple Google clicks) you shouldnt have to worry about detection, also FYI if you do end up searching and comparing products Beltronics IS Escort, escort acquired them in 2000 they are known as Belscort by enthusiasts
The only radar/laser detector which is tested as undetectable by "radar detector detectors" used by police is the Beltronics STi / STi XR. I used to have one, but got over it and sold it. Top unit. The valentine one sometimes has more range and a cool directional "bogie" counter system, but it's detectable by RDD's.
check out http://www.delonixradar.com.au/radar-detectors/tests/
last i heard they have detector detectors, and if they think you have one in your car GL.
As funny as this is, yes :P
Yeah, interesting points there fellas.
Ah well, stick to the speed limit and you'd be fine :devil:
I have been searching this alot and I can't tell you the actual penalty as it's a summons to court offence so it's up to the Magistrate as to what penalty you will get. I have found that it's offence to possess, use, sell or own a device under Road Safety Act 127/1986 Section 74 (1).
Hope this helps and obviously they can be detected and vehicle searched for same and if located should be seized for court and eventually disposed of.
    • It might be worth having a good look at the chassis behind the bumper then; most people prefer the series 2 look so it might have been changed to cheaper parts as part of an earlier repair
    • The car itself a series 2. I was just curious about the headlights and just wanted to confirm that they were series 1. Good to know the rest of the front end is series 1. It’ll be easier for me to find parts on the aftermarket side of things lol
    • If you've wired up the coils & injectors properly, & have the neo CAS loom for the trigger, it should all work. The VCT works the same way so just different plugs between s1 & neo. Assuming DBW if no IAC. Don't bother with the stock boost solenoid with g4x.
    • THERE IS NO IAT SENSOR ON ANY SINGLE TURBO RB. And the one on an RB26 is not for "engine control" - it's really too big and too slow and is only used for over-temp alarming (as far as I can tell). Anyway, you don't have one. You want/need one for the Link, then you need to buy one, find a spot for it, and wire it in. You do know that the stock boost solenoid is not capable of "control", right? It is merely on or off, for the low boost (5 psi) and high boost (7psi), which the ECU enforces mostly based on gear. The stock solenoid is not for PWM control and is not plumbed up in a way to provide it. If you want to control boost properly, then you need a proper MAC valve. And yes, you can wire either of them direct to the ECU. Well, I assume you can - I don't know what the boost solenoid pins on the plug and play Link are capable of. They really should be as capable as any normal Link - but seeing as it is plg and play, it might be limited to stock functionality. Read the doco.   You really do just want to plug stuff together without understanding how it works, right? I can't help you there. I don't know the plug types or pinning on half the stuff you're asking about. If I had to do it I would sit down with the wiring diagrams, the car/looms and a multimeter and work out what is what.
    • Light should be a pressure switch, not a sensor.
