I think this issue is going to be one of those things based on what pressure the engine runs . If its higher than std then obviously something has to be done for the turbocharger . As Dirtman said restrictors are a far simpler means of restricting oil flow to the turbo but always remember that restrictors are flow related not pressure .
Anything in the system crud wise will damage engines and turbos so really everything has to be as clean as possible . I'm not really sure about the 0.8mm restrictor getting blocked up , if you had crunchy bits that big in the oil then you've got real problems downstream of the pump and filter (main oil filter) .
An oil strainer in the turbo oil line may not be a bad idea but you want to inspect them often , lack of oil kills turbos real quick .
If you really want to keep an eye on this theres no reason why you couldn't have an electric sender type oil pressure gauge in the oil line and experiment with restrictors . At least with the sensor there you can differentiate between engine oil pressure and turbo oil line pressure .
As a point of interest some businesses are turbocharging Quad bikes and their engines are more bike like than car engines - roller crankshaft bearings .
They survive very happily on "low" oil pressure - something like 10-15 psi but don't quote me .
Bush bearing turbos like a bit more than that so turbo'd bike engines seem to do better with ball bearing turbos because that bearing system doesn't need the extra flow and pressure that bush bearing turbos and slipper crank bearing engines do .
One thing I do know is that excess oil flow in ball bearing turbos adds extra drag for the balls so its something to avoid if you want good turbine response .
A .
Wouldn't an in-line filter (aka XR6 turbo) cure blockage worries with running small or multiple restrictors? The filter itself may knock a few psi off the pressure too?
Actually I'm sure hypergear supply in-line filters. http://www.nissansilvia.com/forums/index.p...howtopic=391141 or http://www.cimotorsports.net/motor-sport-p...oil-filter.html
yes i forgot to add that i also recommend using (and do use myself) a Peterson filter in the oil feed line to the turbo. It saves your turbo if your engine happens to chew on some bearings.
What micron filter size are people using in the Peterson in line filters - I note there are a few sizes? Also which is better...with or without the bypass?
Edited by juggernaut1
you use the -4 valve train spraybar filter 1/2 way down this page. Peterson part number 09-0730 its 60 micron.
http://www.petersonfluidsys.com/filter_oil.html
Edited by DiRTgarage
lucking i didnt go and buy my oil lines today for my new turbos, i never thought about this.
ive got 2 x greddy td05 18g oil cooled only and ive got to get new lines made up what restricters should i run if any? and where do i get them from
also got standard oil pump
cheers
This protects the turbo from particles, but not starvation - assuming you are running with two restrictors and have one in at the block as well.
So really you need a restrictor after the peterson, and then another one at the turbo, rather than one at the block and another at the turbo??? That way all muck gets filtered before any restriction and also before the turbo.....
Am I right in my thinking? And would that be a better set up?
Dirt suggested a 2mm restrictor at the block....if you've got particles in your oil that are around 2mm I think you've got bigger issues and the placement of the restrictor will be academic.
cheers
They are not as fragile as the roller bearing units, i would not waste my money. Run normal line without restrictors for the TD series.
But he also said engine failure, so your still starving the turbo, anyway, I'm in an industry where tiny particles jam together just like the thee stooges all trying to get out the door at the same time - irrespective, my question and the logic behind it still stands, why put a restrictor before your inline filter?
I'm in an industry where tiny particles jam together......
So your in the vacuum cleaner industry? :(
Your logic is sound - put the restrictor after the filter.
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
