Hey All,
After the death of my built RB26, I have a few GOOD parts left which I need to sell:
1. 6 Boost Manifolds. Steam Pipe with welding by Kyle at 6 Boost. These are also ceramic coated by CIC in Kelmscott (a sponser of Antilag). Retails for $1200. $800 neg.
2. Ross Tuffbond Harmonic Balancer. Only 1000kms old. Bought new. $450 neg.
3. Sard 800cc Injectors with Sard fuel Rail. Few years use. $900 neg.
4. Adjustable Cam Gears. No degree markings. $100 neg.
5. ARC R32 GTR Airbox complete with ARC filters. $350 neg.
6. GReddy/Trust Adjustable Cam Gears, New in box never used. $400 firm.
7. Set of 6 Argo conrods. In good working order. $700 neg.
8. Cam cover set. See link below for pic:
http://i227.photobucket.com/albums/dd180/i...te/IMG_0031.jpg
$300 neg.
9. RB26 Head with the following specs. It needs to be serviced to ensure reliabilty though. Specs below:
- Head fully serviced by Head Exchange WA
- Head machined to accept Jun cams
- Jun 272 10.5mm Cams
- Tomei Cam Studs
- Jun Valve Guides
- Jun Valve Springs
- Precision valve shims
$1000 firm
Pictures will follow ASAP.
PM, SMS or Call Adam on 0424 982 764.
All items located in Perth. Happy to ship interstate. Check out my immaculate trader rating for the last two years. :thumbsup:
6boost manifold for low mounts by the looks in your picture mate?
More info please sir.
Bought brand new from Kyle @ 6 Boost last year. I then got them ceramic coated at CIC in Kelmscott. They are in as new condition. None of the coating has started to come off.
I will include that custom made rear turbo outlet pipe in the sale (Save you a few hundred there).
OK,
I still have the following for sale. Make an offer as I am in a generous mood!!
1. Sard 800cc Injectors with Sard Twin Entry Fuel Rail (Can seperate, injectors won't fit stock fuel rail so best to buy as a bundle). - $800 neg
2. Argo Conrods (Retails for $1166 from Argo) - $600 neg
3. Arias Pistons (With wrist pins and pin locks, will need new piston rings - Retails for $1150 from Rocket Inductries) - $600 neg (And no they are not damaged and ready to be reused)......
4. Cracked RB26 Block (Can be re-sleeved) - $Make an offer
5. Brand new never used GReddy/Trust Cam Gears (In/Ex) - $400 neg
6. Feild ETS-C with cable (have basic wiring diagram in Jap/Eng) - $400 neg
7. 6 Boost Manifold with Custom Rear Turbo Outlet Pipe - $700neg
Manifolds sold and sent.
Stuff still for sale:
1. Argo Conrods (Retails for $1166 from Argo) - $600 neg
2. Arias Pistons (With wrist pins and pin locks, will need new piston rings - Retials for $1150 from Rocket Inductries) - $600 neg (And no they are not damaged and ready to be reused)......
3. Cracked (In bore 5) RB26 Block (Can be re-sleeved) - $Make an offer
4. Brand new never used GReddy/Trust Cam Gears (In/Ex) - $400 neg
5. Feild ETS-C with cable (have basic wiring diagram in Jap/Eng) - $400 neg
http://i227.photobucket.com/albums/dd180/i...ts/IMG_0231.jpg
http://i227.photobucket.com/albums/dd180/i...ts/IMG_0232.jpg
http://i227.photobucket.com/albums/dd180/i...ts/IMG_0233.jpg
  • 4 weeks later...
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
