I am looking at replacing my stock clutch fan with a twin thermo set up and these have caught my eye.
R32 Fan Shroud
If I go down this path I will use the Jaycar kit # KC5381 to control the twin fan setup.
found @ Jaycar
Can anyone vouch for these units or are they just a waste of time and money?
Cheers!!!
https://www.sau.com.au/forums/topic/293145-mishimoto-fan-shrouds-r32/
best thing I ever did to my 32GTR cooling wise was go back the stock setup
much more consistent for track days an just general driving around but mostly trackdays
that said the thermofan setup put on by a previous owner was shithouse
would be very interested to hear if you get this what sorta quality it is an if you have good results?
agreed.
But those rad shroud kits are a bit dear (can get rad and setup for that price from ASI on ebay)
for a fan controller use this, it is the best ive used full stop. http://shopdrift.com/Products/D1-RFCD12V/R...troller12V.aspx
Nice controller!
Are those ASI radiators any good?
depends on the model car, they are cheap so dont expect much but so far no major issues (except AE86, we've used about 10 so far in diff cars), i wont be putting one in any decent track cars though. We flow tested a ASI GTR version against the KOYO and greddy ones and they were a long way behind (i think the ASI (and most cheap china rads) top and lower tanks are too small)
Edited by URAS
Well after a bit of research I have decided to go and build my own shroud and use 2 x 12 inch 1000 cfm fans from Davies Craig.
If it all goes pear shaped I'll just buy a new fan clutch from Davies Craig and retain stock setup.
Will be a bit of a challenge to get it right but that's what its all about.
Will post a few pics once done.
Fair enough, I had one of those Mspec ones from the groupbuy ages ago and not really happy with it. Going back to the 32R radiator, keeping engine fan, twin thermos on the front, have removed aircon and will be going slightly nuts with the ducting.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
