hey guys quick question, am i looking for an R33 front pipe or an R34??? ive got a S2 so are the diferences with the turbo possition or the floor plan difernces... or do they both fit??? confirmation would be great, thanks
You need a R33.
R34 are approx 100mm longer to the cat
Are you after a turbo back to cat or dump pipe to cat?
I need a dump to cat as well. Have a GCG dump to suit the 3076.
https://www.sau.com.au/forums/topic/293151-s2-front-pipe/#findComment-4895657
You can always buy off the shelf parts for the stagea. Fujitsubo does one I have the front pipe and catback for mine. Fits beautifully no mods and it is all in stainless steel. I think the from pipe on its own is around $600 from memory (going back 2 years now)
https://www.sau.com.au/forums/topic/293151-s2-front-pipe/#findComment-4896062
I got R34 front pipe and turbo pipe, all lined up, brackets as well, with the cat, which is in the factory position.
Interesting. When I compared a r33 and r34 all in one dump pipe with each other the R34 was longer by approx 80-100mm
I run a series 1 cat back and r33 dump in my series 2. Maybe series 1 and series 2 cat backs are different lenghts??
https://www.sau.com.au/forums/topic/293151-s2-front-pipe/#findComment-4896197
dont get the JJR one, they forgot about the cross-member, after its cut and re-welded, it looks like the Blits one on justjap.com.
I've got the exact same problem. Gona get a mate to cut it n weld in some straight stainless steel to make it right.
I even called just jap to tell them n had some idiot tell me that it was right cause it said it on the box. I was like clearly its not right, cause its on my car n hits the transfecase mount.
https://www.sau.com.au/forums/topic/293151-s2-front-pipe/#findComment-4898812
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
