Hello,
I am looking at dropping a S2 RB25DET into my Datsun 280Z. I am wondering about the entire buildup process and have been collecting a lot of information. One thing I cannot seem to find is the actual, physical design difference between RB25 valvetrain and RB26 valvetrain. I understand if they have different springs and whatnot, but from everything I have seen, they are both shim over bucket and therefore equal in design? I know RB26 cams do not cross with 20/25. What am I missing? Are the dimensions merely different? Anyone have a photo of the valvetrain of 25 vs. 26? I like the idea of the RB's rev-ability and want to know how the 25 is rated compared to the 26.
Thanks,
Mark from Ohio
https://www.sau.com.au/forums/topic/293159-rb25-vs-rb26-design/
26 has solid lifters and RB25 has hydraulic, thats the main difference. When you switch a 25 over to solid lifters there is next to no difference between the two, pm fineline on these boards if you want to know all the details, he got that all done and now runs 26 poncams in his 25 head. And in regard to revability the solid head will rev more as it wont have hydrailic lifters 'pumping up'
OK, now I am well and truly confused. Aren't the cam lobes riding right on top of the bucket/retainer/valve? Kinda like Subaru STi's? Where are the lifters at?
if you can get the r33 workshop manual it has a really good expolded view of both the heads, it is readily available for down load, its kind of a bit hard to explain and im at work so i cant download the pictures myself!
In the RB26 head seen from the cylinder up; first the valve, then the vavle spring around it, sitting on top of the valve is a shim for the correct clearance, on top of that the lifter to take the hit from the cam knuckle :devil: Very straight forward, standard design.
In the RB25 you've got the hydralic lifters with all-in one-design instead :P
BTW the rb25 have got smaller diameter valves, guess you know this already!
In the RB26 head seen from the cylinder up; first the valve, then the vavle spring around it, sitting on top of the valve is a shim for the correct clearance, on top of that the lifter to take the hit from the cam knuckle :happy: Very straight forward, standard design.
In the RB25 you've got the hydralic lifters with all-in one-design instead :)
Oh, so the 25 does not have a bucket, but rather a lifter that is axially inline with the valve. I take it there's no way to change to the bucket design short of buying a 26 head?
I found the manual. Thank you. I think I see how they are different. I've never seen a hydro lifter of such design. I guess you get the benefit of hydro lash adjustment without the possibility of spitting a rocker or adding undue weight to the valvetrain.
    • A HICAS fault really should not cause the engine to go into limp mode. These cars are so old that the systems barely talk to one another. The thump might be the lockoff solenoid valve for the HICAS (the safety valve) getting closed, to lock the rear wheels "straight". I say "straight", because when my HICAS used to shit itself before I took off and nuked it from orbit, it would lock up with the rear wheels wildy non-straight and you'd need 45° of steering wheel to drive straight. Take off and nuke it from orbit. First step is to pull the smaller of the two plugs out of the HICAS CU. See if it stops misbehaving. You can also (whilst leaving it plugged in) try to get the HICAS CU into diagnostic mode by doing the pedal dance, or by connecting a CONSULT capable diagnostic reader into the car and seeing what it has to say for itself. Can't do either of these with it unplugged though. 1st gen HICAS is a ballache. I would do a complete delete. I did do a complete delete.
    • Ah. I dunno why, but I skim read your earlier post and thought the manual switch was to force it on, not force it off. I'd be tempted to have both. So, your two in series, and another in parallel with those. Or, a master arm switch, followed by the manual force on and the thermo in parallel. 6 and 2 3s.
    • Yeah been doing it in an x shape. Do you reckon it's worth putting guide coat early where the filler isn't sanded down completely smooth? Reason I ask is because as I'm sanding it one part might be level which I don't need to sand anymore but the other part might be high so I can just focus on that instead of sanding across the whole repair area. I wonder if the putty is too thin, though the area is almost completely smooth before I do it as I've already put filler prior.
    • Just 2, and inline. One switch temp related other switch driver controlled.   I'm nearly in my head back to Arduino land for it...
