Hello,
I am looking at dropping a S2 RB25DET into my Datsun 280Z. I am wondering about the entire buildup process and have been collecting a lot of information. One thing I cannot seem to find is the actual, physical design difference between RB25 valvetrain and RB26 valvetrain. I understand if they have different springs and whatnot, but from everything I have seen, they are both shim over bucket and therefore equal in design? I know RB26 cams do not cross with 20/25. What am I missing? Are the dimensions merely different? Anyone have a photo of the valvetrain of 25 vs. 26? I like the idea of the RB's rev-ability and want to know how the 25 is rated compared to the 26.
Thanks,
Mark from Ohio
https://www.sau.com.au/forums/topic/293159-rb25-vs-rb26-design/
26 has solid lifters and RB25 has hydraulic, thats the main difference. When you switch a 25 over to solid lifters there is next to no difference between the two, pm fineline on these boards if you want to know all the details, he got that all done and now runs 26 poncams in his 25 head. And in regard to revability the solid head will rev more as it wont have hydrailic lifters 'pumping up'
OK, now I am well and truly confused. Aren't the cam lobes riding right on top of the bucket/retainer/valve? Kinda like Subaru STi's? Where are the lifters at?
if you can get the r33 workshop manual it has a really good expolded view of both the heads, it is readily available for down load, its kind of a bit hard to explain and im at work so i cant download the pictures myself!
In the RB26 head seen from the cylinder up; first the valve, then the vavle spring around it, sitting on top of the valve is a shim for the correct clearance, on top of that the lifter to take the hit from the cam knuckle :devil: Very straight forward, standard design.
In the RB25 you've got the hydralic lifters with all-in one-design instead :P
BTW the rb25 have got smaller diameter valves, guess you know this already!
  brother_david said:
In the RB26 head seen from the cylinder up; first the valve, then the vavle spring around it, sitting on top of the valve is a shim for the correct clearance, on top of that the lifter to take the hit from the cam knuckle :happy: Very straight forward, standard design.
In the RB25 you've got the hydralic lifters with all-in one-design instead :)
Oh, so the 25 does not have a bucket, but rather a lifter that is axially inline with the valve. I take it there's no way to change to the bucket design short of buying a 26 head?
I found the manual. Thank you. I think I see how they are different. I've never seen a hydro lifter of such design. I guess you get the benefit of hydro lash adjustment without the possibility of spitting a rocker or adding undue weight to the valvetrain.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
