Originally I posted this on SilviaWA forums as it was more relevant there, but a friend suggested this may be of interest on here due to the frequent discussions of engine transplants... Hope I'm not breaking any rules, and I apologise to anyone who might have already read the original post...
*Paste excerpt*
I got talked into trying to fit a VH41DE into my old S13. Yeah, it's a pretty tight fit and it was reasonably difficult. It might stuff the handling, but that didn't really bother me much as it will probably tail-steer fairly well. I'm planning to get it certified and permitted, and it has been approved in principle by technical section before I started, pending certification of suitable brakes... fairly standard requirement. No, it hasn't cost a fortune thus far but it's not completely ready as the photos will show, but yes, it runs and yes, it is the most awesome noise I have ever heard come from an S13.
I'm willing to answer any technical questions anyone might have if you want to come and find me and check it over... I don't recommend you consider doing anything similar unless you too are a half-crazed engineering student with alcohol poisoning and a lot of understanding friends. This is not easy, but it is possible. We won't know for sure if it's even worth it for a little longer, the car isn't yet ready to be driven with nearly 300bhp in stock trim.
If anyone knows of someone else who has done this transplant I'd be interested in comparing sketchbooks with them. I'm not sure if this is the first one in Perth, it's been hard to find any info on the web...
You can be guaranteed it won't be the first in the world, because no doubt some little workshop in the backblocks of Osaka have probably been there and done it twice before, and the yanks have been doing wierd things to 240's for years.
It might not even be the first in Australia either, can anyone clarify this?
Silfiniti pictures and video available here
Obzai
Special thanks to:
Ian from Alltune Engineering
AJ and Iwanz from Speedworks
Mayhem
Damo
Daze
And the rest of the gang who at some time or another have lifted a spanner
and who did their best to reign in a rapidly escaping secret...
https://www.sau.com.au/forums/topic/29320-v8-silvia-silfiniti/
just watched the video...oh sounds scarey...hate to line up against that on the street..reminds me of the part on 2f2f when the rice box is racing the american muscle car. :( very nice work.
OMG.
I saw the video and that's what I want.
The 4.5 litre VH45 Nissan in my Skyline.
Deep down I don't like turbos... I really want a v8 under there...
T.
I'd just like to thank you guys for your responses, I was kind of expecting to get a bit of a smackdown to be honest :)
I've put a few more pictures up at the same link, this time a few more detailed shots, but if you're truly curious as to how it was done feel free to come and find me and say hi, and I'll point out how, what and why we've done it the way we did... much easier than having to try and figure it out by pictures :)
Obzai
Did you guys use the Infinity Xmember or a modifyed S13 one?
Ants been thinking about a turbo VH44 into his Datto 1600, Sic puppy.
Standard s13 x-member all be it with some minor mods to the moutns to account for the slightly different location and angle of the vh41 mount, nothing to extreme, and a customish gearbox x-member..
Nothing most people couldn't knock together with a bit of time and some good welding and fabrication skills
I'd just like to thank you guys for your responses, I was kind of expecting to get a bit of a smackdown to be honest :rofl:
You should see a thread we had going in the past about sticking V8's into Skylines.
Why I think I was called a knuckle dragging neanderthal because I wanted to stick a V8 into my car!
The bottom line is that a VH45 Skyline is still a Nissan thru and thru and we like them fast and loud and this certainly is all the above!
T.
Well done Obsydian for the conversion! :cheers:
My brother was at Speedworks when they started it up and he said it was absolutely awesome! Can't wait to see it in real life for myself! :O Hopefully it won't be at the lights!!
It sounds like, ummm, well it sounds like an angry V8 Drag car. Very Loud!
  • 4 weeks later...
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
