I have for sale my 32 sedan
after an evo 7 which i will be getting imported soon so no swaps
here is a run down of what its got
1989 R32 GTST Sedan
Manual White
rego till March 2010
Engine – rb20det
176xxx kms on clock (series 2 dials) 146xxx on engine
Garrett hiflow turbo – custom made by Rotomaster
full 3inch turbo exhaust and hi flow cat – batmbl split front/dump, xforce 3inch cat convertor and tanabe medallion catback (not to loud and gives a nice note)
gtr injectors and resistor pack
splitfire coilpacks
JJR return flow intercooler setup – legal piping kit
Walbro 500hp fuel pump
Apexi cam gears
Gates racing timing belt
Standard airbox with blitz panel filter
Gtr bov
MSpec dual core alloy radiator – silicon radiator hoses
HD cushioned button clutch
Has all the inlet piping/manifold powder coated ripple black and the engine covers powder coated red
Last dyno run made 225rwkw on 19psi at CREATD Motorsports (have dyno sheet)
Electronics
rb26 AP power fc computer - converted to run on the rb20
Gizzmo MSIBC EBC
Suspension & Braking
Largus coilovers (jap brand)
8kg fronts and 6kg rears
32 point damper adjustable
Height adjustable
(have the adjusting spanners)
Front strut brace
Alloy steering spacer
15000km old rda rotors on front
QFM A1RM pads
Hicas lock bar/hicas lines and pump completely removed
Has fairly new castor bushes
15000km old rack mount bushes
15000km old upper control arm inner and outer camber adjustable bushes
15000km old inner rack end
15000km old rack boots rubbers
15000km hicas inner rack ends
All suspension work was carried out by Centreline Suspension
Will supply ADR approved braided lines depending on sale price
Wheels
Rota D2
18 x 9 +30
235/40 goodyear eagle f1 all round – 95%
Rays wheel nuts in red
Exterior
Vertex side skirts and rear bar
Aero option front bar
TBO front lip (very rare and expensive to buy)
genuine n1 gtr bootlip
Flared front guards
Interior
retrimmed headliner in black
seats have the letherette covers in red and black
door trims retrimmed in red
el dash dials
and apexi el1 boost gauge
original series 2 floor mats in excellent condition
series 2 centre console and shifter surrounds
series 2 dials ( underneath the el dials) – shows 30000km more than whats driven
infinity 6x4’s in front doors
infinity 6” splits on parcel shelf
kenwood double din headunit
note: car has rear wiper attached as its not seen in pics
Car is in Melbourne
and looking for about $16500ono
call Nick on 0432 224 681
genuine inquries only and no swaps
https://www.sau.com.au/forums/topic/293212-r32-gtst-sedan/
  • Replies 54
thanks roy
yeh its a great car, drives like new, got the power and looks
but im a bit over it, had it for 4 years now wanting a change
most likely be getting an evo 7 found a nice one just need to sell first
https://www.sau.com.au/forums/topic/293212-r32-gtst-sedan/#findComment-4920369
thanks russ
there was a guy that had it from ballarat
took me ages to find, came on hes car from japan
last time i was quoted from import monster it was $500 unpainted to bring in
so its fairly expensive for just a lip, so i havnt seen 1 yet on any other car
https://www.sau.com.au/forums/topic/293212-r32-gtst-sedan/#findComment-4921009
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
