I have for sale my 32 sedan
after an evo 7 which i will be getting imported soon so no swaps
here is a run down of what its got
1989 R32 GTST Sedan
Manual White
rego till March 2010
Engine – rb20det
176xxx kms on clock (series 2 dials) 146xxx on engine
Garrett hiflow turbo – custom made by Rotomaster
full 3inch turbo exhaust and hi flow cat – batmbl split front/dump, xforce 3inch cat convertor and tanabe medallion catback (not to loud and gives a nice note)
gtr injectors and resistor pack
splitfire coilpacks
JJR return flow intercooler setup – legal piping kit
Walbro 500hp fuel pump
Apexi cam gears
Gates racing timing belt
Standard airbox with blitz panel filter
Gtr bov
MSpec dual core alloy radiator – silicon radiator hoses
HD cushioned button clutch
Has all the inlet piping/manifold powder coated ripple black and the engine covers powder coated red
Last dyno run made 225rwkw on 19psi at CREATD Motorsports (have dyno sheet)
Electronics
rb26 AP power fc computer - converted to run on the rb20
Gizzmo MSIBC EBC
Suspension & Braking
Largus coilovers (jap brand)
8kg fronts and 6kg rears
32 point damper adjustable
Height adjustable
(have the adjusting spanners)
Front strut brace
Alloy steering spacer
15000km old rda rotors on front
QFM A1RM pads
Hicas lock bar/hicas lines and pump completely removed
Has fairly new castor bushes
15000km old rack mount bushes
15000km old upper control arm inner and outer camber adjustable bushes
15000km old inner rack end
15000km old rack boots rubbers
15000km hicas inner rack ends
All suspension work was carried out by Centreline Suspension
Will supply ADR approved braided lines depending on sale price
Wheels
Rota D2
18 x 9 +30
235/40 goodyear eagle f1 all round – 95%
Rays wheel nuts in red
Exterior
Vertex side skirts and rear bar
Aero option front bar
TBO front lip (very rare and expensive to buy)
genuine n1 gtr bootlip
Flared front guards
Interior
retrimmed headliner in black
seats have the letherette covers in red and black
door trims retrimmed in red
el dash dials
and apexi el1 boost gauge
original series 2 floor mats in excellent condition
series 2 centre console and shifter surrounds
series 2 dials ( underneath the el dials) – shows 30000km more than whats driven
infinity 6x4’s in front doors
infinity 6” splits on parcel shelf
kenwood double din headunit
note: car has rear wiper attached as its not seen in pics
Car is in Melbourne
and looking for about $16500ono
call Nick on 0432 224 681
genuine inquries only and no swaps
https://www.sau.com.au/forums/topic/293212-r32-gtst-sedan/
  • Replies 54
thanks roy
yeh its a great car, drives like new, got the power and looks
but im a bit over it, had it for 4 years now wanting a change
most likely be getting an evo 7 found a nice one just need to sell first
https://www.sau.com.au/forums/topic/293212-r32-gtst-sedan/#findComment-4920369
thanks russ
there was a guy that had it from ballarat
took me ages to find, came on hes car from japan
last time i was quoted from import monster it was $500 unpainted to bring in
so its fairly expensive for just a lip, so i havnt seen 1 yet on any other car
https://www.sau.com.au/forums/topic/293212-r32-gtst-sedan/#findComment-4921009
    • If you want to do a single throttle body conversion easily, you won't need to pull anything apart. Take the linkage from your throttle off the linkage controlling the ITBs. Now open the ITBs wide open, and lock the linkages in said position. Now add a single throttle body onto the front of your inlet plenum. No it's not ideal for the last nth of a kw, but it'll be a lot better than what you're already trying to do...   PS, ITBs can be so damn hard to tune from, because roughly 20% movement in a throttle body equates to a change in roughly 80% of its flow (Hence power). When you add up the flow limitations of those small throttle bodys, it is a LOT higher than that of a single large throttle. Hence, TPS is very very sensitive with them, and you do a LOT of work with sensor fusion, and some Maths behind the scenes to make those blends nice, and be smooth.
    • Yep, when Haltech purchased Adaptronic, and all of the Adaptronic staff, including Andy went with it, it took Haltech to the next level. Haltech wanted Adaptronic as they wanted things like Andy's fuel models, and some other IP, AND they wanted Andy too as he is brilliant! Andy has spoken about the incompatibilities between the old 1500 stuff vs Nexxus, and it totally makes sense. It's not JUST software that is different, there is huge changes in the underlying hardware too. It's why Haltech has had soooo many changes in the last couple of years, in terms of Hardware, and Software, and why it has become so damn Amazing. Why do you think guys like Rob Dahm with his quad rotor, went from running Adaptronic's to running Haltechs? Andy. Pretty much, Haltech these days, is Adaptronic, but with more funds behind it, and more staff, and hence Andy's visions, and visions of other people that he helps shape their great visions, into amazing new products. All the new Nexxus gear, whole new software for it, new and better dashboards, the apps that will run on headunits and NOT be slow to respond! I understand people being burnt in the past, but if you're ragging on a company, about products and issues from many years ago, it's more a reflection on yourself, not looking or keeping up with new stuff. In which case, those people should be going back to PowerFC and Nistunes as the ECU's to rave on about...
    • Right, but I thought the problem has been for a while now that even if you know manifold pressure + throttle position you still have non-linearity and aliasing issues vs actual engine load? One way I can see things simplifying is going DBW, then all air going into the engine is represented by the throttle position. As opposed to a random bimetallic strip vaguely linked to engine temperature opening and closing a shutter or some random power steering air valve suddenly allowing a bunch of bypass air. But the same throttle position/RPM at ~atmospheric MAP in different gears is not guaranteed to be same engine load? Honestly, ITBs are of such dubious value IMO. I don't know why these things are hyped up so much. The main benefit as far as I can tell is you reduce the likelihood of cross-cylinder EGR scavenging with significant cam overlap at idle. I would absolutely run speed density and be done with it if not for this fairly esoteric control problem.
    • Hah dont worry, my adult brain has this conversation every single day. Dont waste your money, invest more of it into shares, pay down the mortgage. Then the bedtime insta doom scrolling begins and after being bombarded with gtr's my mind is set: im definitely getting one! I have the current model mx5 as the weekender, but i just miss my boost and literally like your username, the sututu's that come with it. I remember with my 2nd supra, as it had twins and vvti, they used to spool real early, like 1,500rpm so you could just be a spooly boy all day long. Some people say they get over it after a while, not me tho.
    • If you need to refinance your mortgage and reset the loan terms back to 30 years and cash out on your equity for "investment" purposes *cough* car parts, I can help 😊
