Please help Skyline Oracles!
I have an R33 gtst, with powerfc, hks gt-rs, and all the supporting mods.
I've been having problems with the idle hunting, so I found the DIY thread on how to clean the AAC valve and idle reset.
I completed this and and until I plugged the TPS plug back in it was idling correctly around 750-800 and not hunting. As soon as I plug those back in, it jumps all the way up to 1500rpm and stays there.
So it has fixed the hunting problem, but now my idle rpm is 1500 instead of the 750-800 I set with the screw on the AAC and what is set in the the powerfc hc.
Does anyone have any suggestions as to what my problem could be and how to fix??
Cheers
https://www.sau.com.au/forums/topic/293216-idle-help/
if it's after u put the plug on,
To me it means something is sending it a signal saying it needs to pick the idle up...
Other wise it would hunt with the plug off...
might be wrong but...
Check ur AFM, and that type of thing...
https://www.sau.com.au/forums/topic/293216-idle-help/#findComment-4896619
Ɨ
Ɨ
