Ok i found a DIY for this else ware on wiki awnsers and thought id bring it here but with pics and a video :devil:
Here is the original place i found the info Clicky
The problem is/was a knocking noise that happens 3 times when turning the wheel to the left or right, then the noise happens again as you turn back.
It isnt a hard fix or it isnt very technical, only tools you will need is a Screw driver not too sure on what size (grabed a random one that was lying around) and a T50 torx tamperproof bit (bought mine at repco $20 for the whole set, dont need the whole set for this tho)
The weight that causes the problem is ment to be to counter balance road vibrations ( i dont really see the difference)
Video of the problem
If you stuff this up in any way its your own fault.
How To Fix It
1. Disconnect battery
2. Take out the Airbag Fuse
Ive already taken it out in this photo, its a 10A red one.
3. Remove the cover just behind the steering wheel, has 5 screws. Pull the steering wheel adjuster down so you have more freedom.
4. Disconnect airbag wire, big brown one covered in foam (i removed most the the cables just to make sure)
5. Pop off 2 plastic covers on the side of the steering wheel and you will find the bolts (one on each side).
Undo them using the T50 bit, quite hard to remove (i even bent the inside bit of one of the bolts)
6. Once you have taken the two bolts off the middle part of the steering wheel will be loose and can be taken out. Their is 1 cable that will still be connected to the airbag so unplug it and take the whole thing out.
7. The problem will be there right in front of you, its the little bit of metal that's sitting in carrier.
Problem was that the little plastic bits that hold the piece of metal inplace where broken (3 out of 4) so it would just move around and make noise.
8. RIP THAT PIECE OF CRAP OUT!
9. Start to reassemble everything, put the airbag back in place and put in the T05 bolts and put the covers back on.
10. Reconnect the wires.
11. Put the cover back on behind the steering wheel, screws and all.
12. Place the airbag fuse back in.
13. Reconnect the battery
14. Start her up the noise should be a distant memory, the airbag light should come on then go off like normal.
DONE!
https://www.sau.com.au/forums/topic/293221-wheel-knocking-metalic-noise-r33/
  • 4 months later...
  • 5 years later...
Legend! Really easy to do!
Make sure you buy the TAMPERPROOF torx bits with the hole in the top.... Don't be like this idiot (me) and grab the first one that sais torx bit, otherwise it's back to bunnings hahaha
Thanks again.
  • 6 years later...
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
