Bringing the car back to stock, so im letting go of my set up. All comes off R33 series2.
Here is whats up for grabs, in the next few weeks as it comes off the car. All parts are still on the car and can be tested.
Garrett 3040 AKA 3082R (600hp)
Manifold
External gate 40mm
Dump pipe
Most braided lines
Comment people usually get around 290-300kw on this set up
price 1500
Split fire coil pack
Comment the car never misfired after i installed these
Price 400 and stock coil pack.
Nismo 555c injectors
Price 600
Apexi PFC
Hand controller
Price 1250
Z32 with Apexi filter
Price 200
Blitz electronic boost controller
Price 220
If im not realistic with my pricing, message me your offer, im going according to what i paid minus 30%-40%.
Contact me on here or sms 0421 864 698.
Pictures:
https://www.sau.com.au/forums/topic/293226-aftermarket-parts-r33/
guys few people enquired about the turbo package. Just to let you know the dump pipe might not be included, ill check with my mechanic on monday. Also, all lines are included in package. First in best dressed on this one. All this brand new is worth well over 3k
Just in regards to turbo package, the turbo DOES come with dump pipe and water and oil lines.
Rear housing is .85 i think
Yes im willing to post it, all tho i do prefer pick up. Postage will be paid by buyer.
Full boost around 3 800. Test drive is still available for now.
Manifold
External gate 40mm
Dump pipe
Most braided lines
price 1500
Manifold
External gate 40mm
Dump pipe
Most braided lines
price 1500
Price 600
Apexi PFC
Hand controller
Price 1250
Price 200
Price 220
Pictures:
Few more items available:
Oil and Boost gauges with piller
Comment comes with connections for boost pressure
price 200
Price 220
19inch rims
Price 1400
Condition Almost new
Front 8x225 Rear 8X245 ---> http://www.skylinesaustralia.com/forums/19...52#entry4897552
Manifold
External gate 40mm
Dump pipe
Most braided lines
price 1500
I can throw in full exhaust, 3 inch straight through for extra 100
This should sell very soon, i wish i had this deal when i was looking for a turbo. Will save heaps on labour as you get almost everything you need, nothing needs to be customized or made up.
This package cost much more than you think: here is rough pricing so people get an idea:
Garrett 3040 AKA 3082R(2000) Manifold(500) External gate 40mm(300) Dump pipe(200+customizing) Most braided lines(200) Only rough prices, but you can see how 3000+ figure is easily reached just in parts, not including the stuffing around and labor to customize all parts to fit the turbo.
im stripping the aftermarket parts tomorrow so if anyone is keen to test any parts today while the car is still running, TODAY IS THE LAST DAY. Monday they will be coming off the car. Cheers
hey man if your planning on selling things seprate i may still be keen on manifold, throw me a pm with some photos, price and just some details about it, cheers
Im taking parts off tomorrow, so if i get to manifold, ill take a picture and post it up, cheers.
Cat back exhaust, includes pouched out cat, muffler to quieten the exhaust. All 3 inch.
Comment: Looks almost like stock exhaust(none of those big "f**k off tips" )black in colour so it doesn't stand out. Not loud, so doesn't catch unnecessary attention from of bacon mates.
Price 200
Pic:
Wouldnt mind some better pics of the whole turbo setup. Can you give some more details regarding age warranty.
Also do you have the compressor side piping, bother entry and exit to go with it?
Age warranty? errr no?
Here are pictures, no warranty mate. Works and excellent codition. Had a mechanic look at it today and he said he would buy it if he didnt have bigger version of it in his supra.
Anyway, lowest ill go is 1500, as it costs much more than that. cheers. Any test inspection is welcome.
Price 400 350 firm
Price 200 150 firm
    • You're not wrong, but more than a few times I've heard of people running into issues where their injector characterization isn't quite right and that approach works for that specific configuration but once they switch over to a new set they discover a whole bunch of stuff wasn't set up correctly. It's slightly more annoying to reverse engineer the OEM MAF transfer function but you already have the sensor wired up to the factory harness so keeping it around for a few weeks more while you figure out the tune is easy enough. I've seen GM also use a combination of both MAF + MAP in their ECUs before, MAF is for steady state and a calculation of the cylinder VE to correct the base VE table, then in transients it uses that calculated VE + raw MAP to determine cylinder filling somehow.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
