Hey guys not really sure how to explain or ask this but here goes;
The car SOMETIMES im not sure how to make the car do it again but it will randomly every now and then some drives it wont some drives it will.. in tiptronic mode going from 2nd gear to 3rd gear when i shift it will have a massive squeak noise i believe to come from the back.. i hav argued with mates taht its back right but some say back left - either way its from the back we can agree on this -
The sound started off as a little squeak... its really high pitched and now its getting louder to the point where over my exhaust, sound system and general conversation i can hear it and it gets alot of disgusted loooks from others on the sidewalk etc when and if it does it..
The car will also do it sometimes when im in high rev's in 2nd and coming to a stop at lights as the rev's creep down it will give a sligh jolt and hey presto theres the high pitchd squeak again..
one day i was at lights and decided to stick her in neutral and give it a little rev.. and it did the high pitch squeak again..
as i said it randomly does it some days it wont do it at all some days it just wont stop... and i dont know how to make it do it.. i hope this is making some sense does anyone know what it could be its really bugging meeee!!!!
:happy::):):down::down:
https://www.sau.com.au/forums/topic/293268-random-squeak/
are you sure its not a belt slipping? i cant think of anything in the bac that might make such a noise, and sometimes its easy for noises to sound like they are coming from places they arent, one time i was sure that my ac compressor had threw its bearings, cos of a loud scraping noise (also got some disgusted looks!) but turned out to be a rear brake pad stuck on and wearing thru the pad
i recently had a car with a slipping drive belt and it would squeal in almost the exact same situations u have mentioned
i suggest you try a can of that sticky belt spray stuff just to quickly and cheaply eliminate or target the problem of a slipping belt
and if it squeals when reved while sitting still in neutral i dont see how any squealing noise can come from the rear of the car, has anyone had a listen while outside the car??
https://www.sau.com.au/forums/topic/293268-random-squeak/#findComment-4897503
nah mate no one has listened from outside the car because i dont know how to make it do it again lol :happy:
for example today i was driving with mates it did 3 massive ones in a row and kept squeaking away a few more times... stopped parked the car for a bit had some lunch and a chat and drove it again all arvo and it did it once again only so its pretty inconsistent..
and yeah u may be right its probably not from the back but it surely does seem like it.. as it gives a slight jolt and the squeak when going from 2nd to 3rd as i said.. i dunno but yeah man thanks ill check out what you said and hopefully that shed's some light
cheers
https://www.sau.com.au/forums/topic/293268-random-squeak/#findComment-4898100
nah mate no one has listened from outside the car because i dont know how to make it do it again lol :blush:
cheers
yeah man...im not to familiar with the tiptronic, mines a manual...and my other car that had the slipping belt was a manual, and would squeal often when changing gears up or down due to the changing loads and speeds of the motor versus the rest of the car
...but usually with the belts its pretty clear that its coming from the front, i just cant think of anything else it could be, does the 'jolt' pull the car foraward or let it slow backward?? cos i would attribute the 'jolt' to be the belt catching and griping and thus puling the car forward again or slipping and letting it backward
like i said i dont know anything about the tiptronic but i cant think of any parts of it that would squeal or squeak, after all, isnt it just gears controled by electrical signals from the paddel shiters?
https://www.sau.com.au/forums/topic/293268-random-squeak/#findComment-4898540
hmmm it holds it back a bit.. jerks backward...
i was in first today in high revs going downhill and it gave a slight jolt and the random squeak :D haha its got meeee stuffed aye
and yeah its definatley coming from under the rear wheels around the suspension area
https://www.sau.com.au/forums/topic/293268-random-squeak/#findComment-4901095
ok so ive put it down to when i have my climate control on (aircon or heater etc) then the squeak is very loud even if i just rev it in neutral or park also when im driving... when i have climate control off it hasnt done it lately??
https://www.sau.com.au/forums/topic/293268-random-squeak/#findComment-4910760
Have you changed your timing belt n idler tensioner pulleys before it happened? When I done mine I got a high pitch screech sound in higher revs n even when revving in neutral, but only when I had climate control on. I took it back n they just adjusted a couple of belts n problem gone. Just when you mentioned climate control it sounded similar to the issue I had.
https://www.sau.com.au/forums/topic/293268-random-squeak/#findComment-4910990
i get this thing here and there to o.o exactly what you said Nathan. higher pitch squealing sound when the revs goes up, especially above 4rpm... but i also noticed it usually only happens to me at night time? and i never use the climate control... is my thing related or.... lol
https://www.sau.com.au/forums/topic/293268-random-squeak/#findComment-4911679
well i tested the theory out tonight with mates.. and its definatley only happening when i hav the air con fan switched on.. with it off it doesnt do the squeak but when its on i can sit ther rev it up and at about 4500 - 5000 rpm it will squeak from teh front...
https://www.sau.com.au/forums/topic/293268-random-squeak/#findComment-4912708
It's the belt slipping as the aircon compressor kicks in. Mine used to do it at higher revs but it can still happen at lower revs- you just may not hear it. Ask a mechanic to tighten the belt if required and it should all be sweet. Alternatively the belt may be old and need to be replaced.
Edited by R34mac
https://www.sau.com.au/forums/topic/293268-random-squeak/#findComment-4912875
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
    • It's all the sound deadening, and extra shit piled into them, plus all the extra (even though it's thinner) material for crumple zones. I can't fathom in modern cars why they need canbus to the headlights, and why the headlights must be vin coded on some cars to the ECU, BCM, and security module! Especially when they claim it's for security, yet, the canbus at the headlights let's thieves steal the car in minutes, so even more cars are being stolen! The Mercedes Sprinter 907 vans. They're a huge van, but a "basic" van. Yet they have that many canbus networks, plus two Lin networks, AND an Ethernet network. Logging a single network alone of 8 byte data frames, and they will generate a 20mb log file in 5 minutes. That's one network, and I can't remember the exact amount, but there's over 10 full CAN2.0B networks in them. I'm not a fan of modern cars, oddly, more and more I hate DBW, and all the bullshittery the cars try and interfere with. But all that bullshittery adds weight, plus crazy regulations on crumple zones, plus, ever picked a modern seat up, half of them have like 4 electric motors in them and will weigh 30+kg each. Then all the motors for things like adjustable steering columns blah blah blah. And did I mention the sound deadening so you can even hear an ambulance right behind you even if you 7.2surround sound is off?
    • Ah ok, yeah it should be flat, I believe the r34 battery tray has these 3 bumps in them they makes it line up and everything is flat, don't see how it would tilt if everything is secured.
    • Agreed it actively wants to kill you which I love driving fast cars slow is my stick
