hello......im currently looking to buy a skyline but when i came across the S15 autech it got me thinking.....what car would be better??
The Skyline GTS R33 Series 2 non turbo or the S15 autechversion non turbo 6 speed manual....
Keep in my i am a P-plate driver....
Which are would be better???(power,safety,etc.)
or if you have a car better than these two, please share.
https://www.sau.com.au/forums/topic/293291-skyline-r33-gts-vs-s15-autech/
if their both non turbo go the s15 it has the same power as the turbo and is lighter then the 33 and of course newer better looking
but i suggest u go test drive both and see how u feel in each of them.
S15 Autechs are R34 GTS money if you want to compare in terms of price, in fact it's cheaper to get an R34 GTS coupe in manual than it is to get an S15 Autech, and in my opinion the R34 GTS is a much better car anyway.
mmmmm you bring up a good point.....but will the skyline have the same grunt as the S15??? without mods.....if not how much $$ extra to give it more power???
btw what about a TRD supra 6 speed manual???? shit??? good?? reliable??
Its not about power, its power-to-weight, the S15 might not have the same numbers but you can bet it'd be just as fast, likely faster. Havent been in the driver's seat of a 15 but I imagine they handle alot better than R33s as well.
It'd be cheaper on rego, insurance, running costs, etc... and I think there's too many 33s running around.
You could get more power avenue out of the R33, being a 6 cylinder, you'll always have quicker response before boost, bigger displacement also helps, and there's a few more parts around for the RBs than the SRs.
Take both for a test drive - its the car you want - not us. Whichever one you like better.
As Kristian said, at that kind of figure, consider the R34 instead of the R33, but then it becomes a harder decision to make :happy:
Don't waste your money.
s15 is newer, lighter, faster, better looking..... Supra is a Toyota so of course its reliable but s15 is deff better option. No question
Actually the last part is incorrect - in a straight line, the Supra is quicker by a fair margin. Around corners it would even up a little. Autechs make good power, but they lack in torque, meaning you have to really drive them hard to get anywhere in a hurry. 2JZs make good torque even in NA form.
A late model SZ-R Supra is similar in age to an Autech, but is also around the same sort of money to buy too. If you're after RWD, then it's certainly one of the better choices.
As for going faster, the usual exhaust, intake, computer mods all help, but the increases are fairly minor when compared with modding a turbo car (or even putting on a turbo for that matter). Best to use it for what it is, then safe the money you would've spent on modding it for buying a turbo version once you're off your Ps.
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
    • That's the thing, they still add it and it makes fuel cheaper, implying adding 10% of it drops the cost of 91 by what, 5c a liter? I remember when it was barely half the price of 98. Because you know, 85% of what is in the fuel is way cheaper than 91 fuel is by volume.
    • Auto electricians that do repairs on automotive AC systems can source service kits. I don't know where they actually source them. I do know that there is one available for the R34 comp that I would need it for. If you have to pay someone to dismantle, clean and do needed repairs and fit kit contents, then you'd probably end up spending a good fraction of the cost of a new one. I would not be paying for that, because I would be doing it myself. My mechanic (bro-in-law) will happily source what is needed. Back in the day (like in the 80s and 90s), rebuilding an AC compressor was the standard approach, same as for starter motors, alternators, etc, because new replacements were v. expensive. After the China manufacturing boom and the rise of the disposable approach to everything, people just started throwing broken/worn stuff away and not rebuilding things.
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
