the sound of the blower on that thing makes dead men cream
jus sayin..
Yeah but it's a Vauxhall...probably the most unglamorous car maker in the UK...a real boner killer.
Fcuk you could get a Porsche Boxter for that price. :happy:
it's holdens mainly, they sell it off to vauxhaul and the used to be pontiac in the US lol
btw
the new ve series 2 hsv's...look like ricers lol not to mention a few notes taken from the R8
Edited by Neuroglider
V8's are an OZ thing? What are you talking about.... Aussie make the worst, most unsophisticated V8's
Ferrari, Aston Martin, Jaguar, BMW, Audi, Mercedes can all produce a V8 capable of 100's more horse power than crappy Falcoons and Commonwhores.
F1 cars are all now 700-780hp 2.4L V8's
pffft!
pffft!
$250,000 vs $80,000
you'd hope you got a bit more power for that sort of a price difference!
watch that video I posted, Austin martin db9 went around the track the same time as the maloo and the bathurst did it in the same time as a bmw M5
thats not something to just shrug off. More power and "better handling" didnt do them much good did it? you pretty much pay over 100 grand extra for a nice badge and cosmetics
put $100k into an R8 or similar and youre going to have a car that wont be beaten by much!
Don't know if you guys are hit by the same token but, at last australians are at least getting recognised as... humans?
I'd take an XB GT over an aston martin db6, just like i'd take a walky-charged R8 over an aston martin.
else, i'd take aston, flog the f**k out of it, sell it, then buy lots of FT-86's when they come out.
erm... yeah. something like that.
Why don't they sell the supercharged version here??? are Holden straylia too piss weak??
I noticed that Car has one of those adjustable flap valve things on the exhaust to control the exhuast noise, isn't that a instant defect sticker if a cop pulls you over?
Not in the UK is would seem.
They're ghey anyway.
pffft!
You can't compare F1 cars to road cars. Those motors rev to 18,000RPM andonly last 1000km's.
And just for the record, in the late 80's the F1 motors, especially the BMW motors, were a 1.5L 4cyl turbocharged running up to 60Psi boost pressure, and those motors were making over 1500hp....
My 323Ci has one of those flaps in the left exhaust pipe from factory? Easy to remove though...
Weren't they forced to cease production of the Monaro as the volume of exports was getting too high? I was under the impression that if they kept exporting then manufacturing of the Monaros would have had to shift to the US.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
