I just recently got a '93 r32 gts4 skyline and I got this part with the car (uninstalled).
I was just wondering how to install it back on and if possible, if I can replace the BOV to a newer one or something?
Can anyone tell me where to install this and tell me some newer style bov's that will be compatible with the setup.
(At the moment i think it's a plumb back)
Thanks peeps.
https://www.sau.com.au/forums/topic/293327-where-to-install-this-bov/
i wouldn't bother for 2 reasons.....
1) cop magnet.
2) no performance value what so ever.
nothing wrong with keeping the factory one on and you pretty much get the bov noise when you put a pod filter on but i would recommend a pod box and cold air induction if you go that way.
Throw that out mate.
Its an unknown brand / make, its installed before the intercooler, and those return lines are clearly a 30 second job in the backyard.
No wonder its not installed, the number of issues running that piece of f**ked up experiment...God only knows.
Ideal setup: BOV installed on the crossover pipe, as close to the throttle body as possible,
pulmbed back intothe induction pipe, as close to the turbo as possible.
Okay, so stick to the stock bov yes?
And btw, can anyone post a pic showing me where the stock bov is on an rb20det and some good suggestions of aftermarket bov to buy with the single 'pshh' sound which will be compatible with the rb20det engine. :thumbsup:
im kinda new with skyline engines
  ye.808 said:
can anyone post a pic showing me where the stock bov is on an rb20det and some good suggestions of aftermarket bov to buy with the single 'pshh' sound which will be compatible with the rb20det engine. :(
Anyone got some nice pics that can help?
Stock BOV is at the very top of the image in the middle. Can't miss it. Kind've looks like a duck wearing a trilby. Okay, maybe not, but it is bolted to a section of the crossover pipe (easy enough to remember as it is the intake pipe that crosses-over the engine).
If your car had a BOV fitted to a section of intercooler piping the stock crossover pipe may have been replaced with a new section of pipe that doesnt have the fitting for the stock BOV or in place of the stock BOV they may have simply blocked it off with a piece of metal.
Luckily both the crossover pipe and standard BOV should be easy to find and cheap to buy.
If you insist on an aftermarket BOV, get one that has an rb20det adaptor so it will bolt straight on. Look in the classifieds section as there used to always be ppl selling as-new BOVs for cheap prices as many people get sick of them after a week or two and dump them for peanuts. Also, you can ask them if it makes a PSH noise like you desire or more of a wapachang which it appears you are not.
LOL!
I just found out that the car was making stupid flutter sounds when i installed the pod filter... The reason was the stock BOV was 'blocked' off ;)
Now since i have the FMIC, Pod Filter, Turbo timer, Boost gauge already. Maybe I should buy a turbotech boost controller($30) and a turboback exhaust?
Edited by ye.808
  Nic_A31 said:
Unblock the BOV...that flutter sound is the turbo spinning up and slowly down repeatedly very quickly. Eventually you'll loose boost and find your turbo blades in your intercooler.
Fix that first - other mods later.
Yeah, i removed what was blocking the BOV, now its maing a nice single 'pshh' sound. Better?
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
