Hey everyone,
Just put a deposit on a auto 98 r34 gt t but have some questions about the car. First off ive never owned a skyline so my knowledge is very limited. Anwyays the car im going to purchase has just been imported to Australia and is going to get complianced sometime next week. I was told that its no longer a plate and is now a sticker. Is this true?
Also being a fresh import is there anything i need to look out for? (i would be the first registered owner) Im a little concerned because im getting the car for very cheap. So something must be up unless his being honest and he needs the money desperately to get his other cars into oz.
A friend of mine said to call nissan and give them the vin number or model number cause some people are bolting on turbos to non turbos and selling them as turbos.
And finally if anyone has anything at all, even something simple they could share with me on what to look for on a R34 i would really appericiate it.
https://www.sau.com.au/forums/topic/293340-r34-gt-t/
    • Honda's hybrid system can be easily scaled up to PHEVs. Series hybrid at low speeds, at higher speeds the engine directly drives the wheels but there can still be some power bled off to charge the battery + the electric motor can still provide parallel assistance too. It's really only a question of will at that point. Toyota's PHEVs are selling incredibly well at the moment because of the flexibility. You can run on EV mode when it makes sense, but if you're planning on doing a long highway drive you can still fire up the gas engine and not have to worry about dealing with the rather miserable state of public charging infrastructure.
    • Only reason to keep a MAF on your RB25 is to be able to easily calculate true VE if you know what the factory voltage curve represents in grams per second of flow. Also allows you to do things like pull the original OEM ignition + AFR target tables and use those as a starting point for your base map. Once you're well and truly done tuning though there's no need to retain the MAF.
    • Do you think they'll merge there performance divisions and we'll end up HoMo?
    • Very true, if buying new, I would not get an PP either. Minimum is an Elite 2500, which is also considered outdated. Get something that supports DBW, delete that cable throttle. Best thing I've ever done to the Skyline, next best is refreshing the A/C with a new condenser. It's cold, but not as cold as modern car, but colder than most 90s JDM shit boxes imported into Australia.
    • Haltech have a nice comparison table between the Elite and Nexus models -  https://www.haltech.com/ecu-buyers-guide/ In general, the Nexus is better. Haltech have some nice product videos on their YouTube page, I'd have a look at those and if you're still not confident what way to go, I'd give them a call. They have the best customer support of any company I've dealt with, I'm sure they'll be able to help you out.
