does windows 7 require a hardware upgrade as most machines did when vista was installed? when i purchased one of my laptops it came with vista, but was running so slowly i took it off and put Xp back on - considering a test of 7, but if its likely to chew up alot of RAM then ill probably steer away. i've only got 1gb ram (not sure why they bothered installing vista on this machine to begin with)
Well to be honest yes work 32bit only.. You need 2Gb at least for 64bit but would't bother unless you have at least 4GB. Windows 7 will work alot better then vista.. but ram is not the only thing you need to worry about...
So your best chance is to go to the following link and run Windows upgrade advisor to see what it says..
Keep in mind that Windows 7 is Faster then Vista by a long shot and Windows XP by enough to be inpressive...
May be worth getting another stick of ram anyhow better performance and like R31Nismoid said it is cheap... Let me know what type of laptop and i can tell you if you can or can't upgrade ram the type and price if you want..
WINDOWS UPGRADE CHECK
  • Replies 112
Been a few hours now, everythings still running sweet.
Couldnt get my head around the new pinning of icons, so i removed them all, then readded the quick launch bar and removed the 'task bar combining' feature so it makes it look like xp / vista again. I took a few screen shots. :D
I might give the pinning another go a bit later on, but will leave it off for now!
Havent found any faults yet this time around! Windows media centre, media player - etc and all the other programs now open sweet. My thoughts are that the original issues were caused by the incorrect driver installs.
post-54322-1256542202_thumb.jpg post-54322-1256542221_thumb.jpg post-54322-1256542275_thumb.jpgpost-54322-1256542852_thumb.jpg
Edited by KR4-GTR
uh huh. ok that makes sense. the first laptop i mentioned previously is an aser aspire 3680. (its pretty crap - i use it mainly for a media center, burning cd's watching movies, itunes, games, tv) and the second i have is a HP mini, which i use strictly for uni stuff, so just office 2007, google chrome, and adobe professional, and windows live. they're the only things installed on it. however i don't think you can upgrade these mini lones can you?
How bizarre, I have both of those machines sitting on my desk atm, both will run W7 fine with 1Gb of RAM, however, I have upgraded both of them to 2Gb for $60 (all up, the 1gb module from the Mini plugs in to the 3860) and they run even better.
that is indeed bizzare, where did you buy your ram from and are they compatible for both laptops of will i need different kinds?
my main concern is compatibility of software, i don't want to go installing W7 only to find out half my programs wont run smoothly on it.
i didnt have any problems in this space, if something didnt work - i just ran it in compatibility mode for xp or vista! :D
While we're on topic - if anyone wants any laptop ram or hard drives - let me know.
I have -
- 4GB DDR2 (2x 2GB sticks) laptop ram
- 320 GB SATA hard drives.
All brand new, taken out of DOA laptops which had cracked screens - etc. The brands will vary - samsung, western digital - etc.
Pickup or post is okay. Quick sale, $100 each. Let me know how many you want :thumbsup:
Note - As most of you would know - as per normal - you must be running a 64 bit OS to get the benefits of the full 4GB ram, otherwise you will still get a percentage usable, just not all of it :thumbsup:
PM me if your interested. :D
Edited by KR4-GTR
I got the memory from DigiWorld in Melbourne, it cost $60 for a 2gb Kingston SODIMM6400 (part no. KVR800D2S5/2G) The 1Gb chip from the HP Mini (1001TU) plugged straight into the Acer and worked fine.
You can always set the compatibilty mode back to Vista or XP.
Worked for everything i use thus far
No problems what so ever with Win7, I'm running Win7 ultimate 64bit on my machine and Win7 ultimate 32bit on g/f's machine, no probs at all. Drivers picked up fine, I did have to upgrade video and mobo drivers to make it run smoother but other than that, no problems at all would highly recommend it! (This is coming from a vista early adopter as well)
Note - As most of you would know - as per normal - you must be running a 64 bit OS to get the benefits of the full 4GB ram, otherwise you will still get a percentage usable, just not all of it :(
Not so with Windows 7. There is now no 4GB Ram limit in 32bit OS. So you can run as much as you like. Have a machine at work utilising 24GB of RAM on 32bit 7 OS.
On the netbook front, I have it running on an 1.7GHz Atom processor with 1GB Ram and it is doing just fine. About to test on 512MB Ram with shitty single core and see how it goes. Just for giggles of course.
Gotta do something that looks like work in teh IT field :D
awesome, but does the mini have room for additional ram? or is it limited due to its size? i dont want to open up and check since im not sure whats what at this stage.
No, there's only one memory slot in it, so I took the 1Gb out and replaced it with the 2Gb, the 1Gb chip went into another PC that I have.
meh, XP for me. living in the dark ages and loving it. all I need is office, some adobe products, and firefox and I'm pretty much happy. lol.
Oh dick that sounds so philistine! :/
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
