I'm selling my custom GT4202R and Moroso 22600 external wetsump oil pump(belt driven). Reason for the sale is I'm going with a 80mm GT4508R and full drysump. Parts are located in Canada.
Turbo sepcs
Condition is 10/10
Compturbo.com
CT5 compressor housing 5" inlet
3.5" Outlet
Polished Turbo Housing
76mm Inducer
102mm exducer
Garrett Compressor Wheel
Aluminum Bearing housing (Limited Production)(half the weight of a standard GT42)
Super X trim exhaust wheel 74.9mm
Single scroll .96 T4 4" exhaust housing
2200 AUS+ paypal + shipping
Moroso 22600 Oil pump
Wetsump
Condition is 9.5/10
Oneof the edges onthe bracket has been grined of for mockup.
Ths oil pump has never been hooked up to line or has ever had any oil in it.
Oil Pump Style Dry sump
Oil Pump Volume High-volume
Oil Pump Pressure High pressure
Good for 1500HP and 14,000RPM
750AUS + paypal+ shipping
new price on the turbo 2000AUS shipped. I'll also do 750 AUS shipped for the wetsump pump. i need these gone asap. The comp wheel on the turbo is the same size as a hks t51 spl but the spool up is much faster.
Edited by FOOT
Its a big single mate. Good for any 6 cylinder or bigger.
hey there bud i am interested in your turbo could you email me on [email protected] please as soon as possible or feel free to call me on 0406995559
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
