I'm selling my custom GT4202R and Moroso 22600 external wetsump oil pump(belt driven). Reason for the sale is I'm going with a 80mm GT4508R and full drysump. Parts are located in Canada.
Turbo sepcs
Condition is 10/10
Compturbo.com
CT5 compressor housing 5" inlet
3.5" Outlet
Polished Turbo Housing
76mm Inducer
102mm exducer
Garrett Compressor Wheel
Aluminum Bearing housing (Limited Production)(half the weight of a standard GT42)
Super X trim exhaust wheel 74.9mm
Single scroll .96 T4 4" exhaust housing
2200 AUS+ paypal + shipping
Moroso 22600 Oil pump
Wetsump
Condition is 9.5/10
Oneof the edges onthe bracket has been grined of for mockup.
Ths oil pump has never been hooked up to line or has ever had any oil in it.
Oil Pump Style Dry sump
Oil Pump Volume High-volume
Oil Pump Pressure High pressure
Good for 1500HP and 14,000RPM
750AUS + paypal+ shipping
new price on the turbo 2000AUS shipped. I'll also do 750 AUS shipped for the wetsump pump. i need these gone asap. The comp wheel on the turbo is the same size as a hks t51 spl but the spool up is much faster.
Edited by FOOT
Its a big single mate. Good for any 6 cylinder or bigger.
hey there bud i am interested in your turbo could you email me on [email protected] please as soon as possible or feel free to call me on 0406995559
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
