post-66494-1256416656_thumb.jpgI Recently Purchased this vehicle off a family friend. I Bought the car knowing he had spent the majority of his life if the mechanical trade and this car was his pride and joy. This is a very regretful sale but i have recently been accepted into the army and no longer need a vehicle. He had someone import the car for him and owned the car since it was imported and yes the kms are genuine, the car is not a front or half cut like a lot getting around these days. The Car is in immaculate condition inside and out, never been smoked in and always garaged. The car hasn't been touched or fiddled with, the only modifications is a front mount into-cooler, a top of the line exhaust system and duel stage boost controller, Turbo Timer as well as defi gauges, and no the gauges are not screwed onto the dash and the dash is not marked in anyway. The car also has had a new spray job as it was sprayed when the front bar and side skirts were fitted. there is a small chip in the front bar and other then that, the car is in a1 condition and you will go far to find a straighter r33. The car will also have 12 months Rego as of 08-11-09 if purchased before then i can knock the cost of rego off the price Features: A/c, Power steering ,Climate control, All power options, Central locking, Tinted Windows.
https://www.sau.com.au/forums/topic/293375-r33-gtst-for-sale/
youd be better off posting this here, its a crazy little section of SAU called the FOR SALE thread -> http://www.skylinesaustralia.com/forums/Sa...s-only-f56.html
you also might like to include:
Your contact details, the price of the car, location of car/you
kms its done, more import details then a friend imported it for my friend....
model of the car.... but from the headlights i can tell its a S1, you should note that down,
year of the car, transmission of the car,
whether it is RWC - ie exhaust may be too loud...
if its under finance at the moment....
do you just expect ppl to throw money at you?
I CAN WRITE IN BOLD TOO!
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
