The motor is fine now, but after I went for a drive testing it out I looked at the engine temp and it can't get any hotter!
The oil and water and full/perfect level. Any ideas on what it could be?
Is there anything I can do/try to fix or find the problem,
this motor was from a jap wrecker freshly put in,
thans
https://www.sau.com.au/forums/topic/293380-car-is-over-heating-r33-gtst/
did you check and change thermostat, waterpump etc, before putting motor back in? my s2 rb25det was overheating aswell when i put it from engine importers, had a cracked thermostat.
My 2 cents anyway
I'll check the thermostat when I get home, if it's broken can I drive without 1 until tomorrow when I can get a new 1?
You can take it out altogether - it will just take the motor a lot longer to warm up so no boosting until you've been driving for say 10 minutes.
You can also try putting the heater on full to keep it cooler.
As ali-t mentioned - did you open the coolant bleeder at the top of the motor to let the air out?
All I done was had the car running whilest filling the radiator and it won't let more in, where is this bleeder ontop of the motor?
As for background of motor, s1 rb25det put into n/a r33 "changed full wiring loom"
If the 25 is like the 30 thermo, it is a bad idea to run without one...
The RB30 runs a strange bypass setup when cold. From waht I've been told, no thermo stat can cause hot spotting in the motor...
Your looking for a bolt with a 10mm head on the cylinder head. Its probably got a sticker near it. On RB26 its quite close to the fuel pressure reg.
This is RB26 but its the nut above the gold sticker
Ok I just got home I'll check it out now, I forgot to mention my thermo fan doesn't turn on... Any reasons why?
i was just bleeding the radiator with the bleeder valve on top of the plenum, and yes there is air coming out with some fluid bubbling out every now and then.
"but" just on idle the stupid thing has gone from half way heat to "HOT" while i was trying to bleed for like 5 - 10minutes... do u guys still think its cause there is air in the radiator?
while its running i plug up the bleeder and check the radiator and the radiator is still full :P
oh and i had the car air running on heat while i was doing this.
should i continue to bleed it while its almost a hot peak? or is there something else i should be trying?!?!
My 2 cents anyway
how do i check the water pump? is the gtst water pump different to the non turbo water pump? if not i could just swap it i guess...
i dont know what it looks like either.
Have you removed the thermostat? If not, do that, re-bleed and see how it goes. Water pumps wear out more than break so if its not leaking or making noise it unlikely to be the problem.
Are you sure the sensor for the gauge is working ok?
If the thermo fan isn't coming on but the gauge says the engine is boiling, then either the gauge is wrong, or the thermostat switch for the thermo fan is cactus.
Does it feel like the engine is extremely hot (if you were bleeding a boiling engine, I'm pretty sure it would be obvious)?
Have you got your old motor?
If you do, grab the temperature sensors from it, and put them in the car instead of the ones that came with the motor.
I've been caught out like this before with the only issue being a sensor... I chased it around for ages checking water pumps, coolant gallerys, new radiators etc etc... Turned out to be the sensors...
Thermostat is out and it's running better whilest driving/boosting it stays around 4-5 mil from the hot sign, when on idle it gets hotter cause thermo fan doesn't turn on for some reason...
I've decided the n/a radiator needs to go!
I'm in nsw and I want a decent yet cheap radiator upgrade for a r33 gtst, can someone suggest a place so I can get it tomorrow!
Possibly leave me a brand name and a rough price, thanks
also where us the closest wire to hardwire my thermofan?
Yeah it's boiling hot alright, where is the thermofan sensor? I don't think the fan has ever kicked in... I was just gonna hardwire it somewhere.
The non turbo radiator must he crap for cooling aswell so I wanna find a cheap yet decent radiator to buy tomorrow! Any suggestions?
has anybody wired the thermo fan to constaly run?
cause mine doesnt work at all... could someone please tell me how to and post a picture guide on
how to wire a thermofan to constantly run as my car is overheating to much on idle.
cheers
You fitted a thermo fan that never turns on?!?! FFS!
Having a thermo on constantly basically defeats the purpose of having a thermo fan (it's called a thermostatic fan because it is controlled by a thermostatic switch). What you gain by removing the load of an engine-driven fan is replaced by the additional load of driving the alternator to supply enough current to drive the thermo fan.
Just put the factory fan back on.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
