You fitted a thermo fan that never turns on?!?! FFS!
Having a thermo on constantly basically defeats the purpose of having a thermo fan (it's called a thermostatic fan because it is controlled by a thermostatic switch). What you gain by removing the load of an engine-driven fan is replaced by the additional load of driving the alternator to supply enough current to drive the thermo fan.
Just put the factory fan back on.
Ok maybe I'm saying it wrong "I have only replaced the engine and loom!" radiator and fan on front are standard non turbo stuff! The fan on the front "whatever it's called" doesn't turn on at all so what we be the problem do u think?
The fan out front is the thermo over-temp fan for the A/C. The switch is the one in the bottom tank of the radiator.
If the engine is overheating even with the factory engine-driven fan fitted, there is an extremely good chance that the impeller on the water pump is cactus, and no water is being circulated to help cool the engine. You will have to pull the pump to confirm.
i had the same problem, replaced thermostat and was good for about a month and then happened again. the real problem was the radiator was 70% blocked. try getting the radiator tested. Its easy to take out and while ur doing that change/check thermostat and flush engine . . . . radiator cost me $110 brand new from nat rad in epping.
yeah i took the thermostat out just to check it and its working better not its gone.
ill be getting a new 1 this friday and ill be changing my radiator to that justjap one.
yes the fan infront of the aircon/radiator "black one" is the one that isnt working.
i dont know why it doesnt... and i have now noticed another problem!
my heat gauge "since engine install" even when cold doesnt go below half way now :D ffs!
i know my engine still is "extremely" hot when its at max temp cause i felt it but
the stupid gauge wont go below half way... any ideas on why that is now?
is there any difference between a RB25 temp sensor and RB26...? Different resistance or something...?
As I have just fitted a 26 head to my 30 bottom end. (was running 25) and now temp seems to warm up really fast.
I dont have another guage to check the temp.
Yes there is a difference,
There's also a difference between R32, R33, and R34 as I said earlier.
You're all prepared to tell this guy to rip his water pump off, buy a new radiator... I did all that and learnt the hardway... GET THE CORRECT TEMPERATURE SENSORS FIRST.
If you have the old motor, refit them!
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
    • I get into huffs with people when I suggest the MX5 looks so much better as a coupe than it does as convertible. Pretty sure I don't prefer the convertible version of anything. Good job on the hardtop! The next buyer will appreciate.
    • IMO wrap does have its uses, but like you said, quality wrap, and professional installation, would probably cost want a quality paint job does, but, the paint, if maintained, is basically for life, and much easier to touch up if required  In other news: it's pissing down here, with thunder, lightning and only some small hail "at this stage", luckily all "my" cars are undercover  I've also been contacted by a guy in Newcastle about the SS, he said he will come down next weekend for a look, we'll see how that transpires I guess 🫰
    • Nah, I'm not an a-hole, ha ha!   I do like the colour match. Some of the carbon fibre wraps are quite freaking horrible. There's one a local company I know uses, and it looks damn good! Also very very expensive per metre to buy! ha ha ha It might be cheaper to respray the roof than use the good CF Wrap, ha ha!
    • Please noooooooo 😭 As for wrap, no thank you mate, I've seen and used "carbon fibre" wrap before, and for these hard tops, they look soooo good when colour matched Like this >>>
