I have for sale my 32 4 Door Gtst
Looking at trades for a v8 or cash
Has the following Mods
1989 R32 GTST 4 Door
Manual Gunmetal Grey
Rego till July 2010
NO RWC
Engine – rb20det
130,xxx kms on clock 120xxx on eng
Standurd Turbo with no shaft play at all
3inch Cat back exhaust with a Jasma rear cannon
R32 gtr Fuel Pump
Coice of Standard air box with K&N filter or Blitz Pod
Standard Blow off valve
Alloy raidator with temp controlled thermo
HD cushioned button clutch approx 5k old
Tein HA adjustable Height and Damper, Front and Rear
Hicas lock bar/hicas lines and pump completely removed
New front break pads rear have about 40%
Standard R32 Gtst Stockies sprayed matt black
Locked R200 Diff Very Tight
Alarm and central locking
Ive also got a Split Dump into Screamer fitted but can fit stock dump on requset
Never been boosted
Front Mount Intercooler
Drift Button Handbreak
Coilpack cover removed to avoid damage to factory coilpaks
Very clean interoir no cracks or bubbles on dash
Boost guage fitted on the drivers side air vent
If theres anything ive forgotten dont hesitate to Pm call or txt me
Car is in Melbourne
Looking for about $7500ono
Call andrew on 0431 404 796
Edited by gelousi
https://www.sau.com.au/forums/topic/293392-r32-4door-for-sale/
  • 5 months later...
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
