I headed down to AIR tonight (06Dec) to lend a hand to Shaun, Ben & co as they were running the 'Boost Worx' backed yellow 2JZGTE powered Supra (ex-RPM car).
Ben ran a string of low 11's @ over 127mph before finally getting the car to run closer to its potential with a PB of 10.8 @ 125+. The mph was down on the earlier passes as an IC hose blew off going into 3rd gear. The car should run closer to 10.4 with a few more tweaks.
All passes were on ET Streets (DOT approved) I'm not sure if they qualify for the HPI Street Drag Challenge or not?
I'm sure most will agree that the 2JZGTE is an awesome engine. Ben's Supra runs a dead stock internals 2JZ.
Another car worth mentioning was the factory standard new 3.5L V6 Magna (base model) whose female driver ran back to back 14.8 - 14.7 mid 90mph passes (best of 14.7 @ 96mph). The only mod was a slight change to the air box feed.
https://www.sau.com.au/forums/topic/29343-boost-worx-jza70-supra-runs-108-125/
Yeah mate sure have!
I remember reading articles on the MKIV JZA80 Supra when it was first released in Japan. It was my #1 choice when I got interested in imports back in the early-mid 90's. They were a touch too expensive back then though :) Hence I got the Skyline instead. I've gone too far with the GTS to start again now :)
Hip,
Brand new ET Streets & a good suspension aligning session made a huge improvement on the strip.
ET Streets are a drag radial tyre made by Mickey Thompson. They're DOT approved which technically makes them street legal.
"There's a simple way of identifying whether or not a tyre is legal for road use. If it has "DOT" or "E" written on the sidewall, it's passable - no probs. DOT is the US abbreviation for the Department of Transport, while "E" is the recognised European compliance symbol. Having said that, it wouldn't be unthinkable to get pulled over by the police for supposedly "bald tyres" - regardless of their technical legality."
The car is with Boost Worx now as the mechanic linked with the car moved from RPM to set up his own workshop. So the car moved with him.
Tim,
I'd say traction would've been a huge factor in who hosed who on the street! Neither cars have/had a lot of traction on road rubber. Ben mentioned turning the tyres @ 180+ on the road.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
