We are a real and genuine seller and trader of ceephones......We are willing to offer discounts serious buyer ...
Buy 2 get 1 free
Buy 5 get 2 free
Brand New Apple iPhone 3GS 32GB Cost $ 300
Brand new Apple iPhone 3G 16GB Cost $ 280
Brand new Apple iPhone 3G 8GB Cost $ 250
Nokia N900 $350
New Nokia N97 32GB Cost $ 300
New Nokia N96 16GB Cost $ 280
New Nokia N95 3G 8GB Cost $ 250
HTC Hero Android G2 A6262 Black Smartphone Unlocked Import $ 380
HTC Touch Pro 2 .$ 350
HTC Magic Android Google A6161 Vodaphone Black Unlocked Import $ 350
Blackberry Curve 8520 Gemini Smartphone Unlocked $ 400
Blackberry 9630 TOUR Smartphone Unlocked. $ 350
BlackBerry Bold 9000 $ 350
Samsung OmniaPRO B7610 Smartphone Unlocked $ 350
Samsung i8910 Omnia HD Unlocked $ 300
Samsung I8000 Omnia II Unlocked $ 400
Sony Ericsson Aino Luminous White Unlocked $ 350
Sony Ericsson Idou Satio $ 350
Sony Ericsson W995A Walkman Progressive Black Unlocked $ 350
In the box:
cell phone
Stereo Headset
Dock
Dock Connector to USB Cable
USB Power Adapter
Documentation
Cleaning/polishing cloth
To purchase it get back with details below :
Where are you located ?
How many you want to buy ?
How soon do you want it ?
For more details about purchase Contact Me via e-mail at
MSN MESSENGER
[email protected]
[email protected]
www.phonesplaza.cc.cc
https://www.sau.com.au/forums/topic/293440-fs-nokia-n900apple-iphone-3gs-32gb/
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
