i hosed my engine bay out last weekend like a dickhead and ever since my r33 hasn't been the same. it idles rough and misses like a bitch upto and over 4500rpm. i've driven it a bit without the coil pack covers hoping to dry it out but still no change and i noticed it seems like it gets worse as the car gets hotter. any advice on this matter would be appreciated thanks
https://www.sau.com.au/forums/topic/293471-rb25det-missfire-problem/
yep water around coils and sparkies.....could have failed coils if old and cracked....mine did the same thing after a coilpack failed....change sparkies, leave them out and leave bonnet open to dry everything out....maybe even leave coils out in the sun.....
might try that. i've read in a topic to regap the plugs to 0.8 and silicone up the coil packs
yep it works... if your coils have the usual "heat crack on the side" problem that most old coils get.
Silicone or (in my case) high-temp gasket maker will fix the problem for a while... obviously if the coil is completely gone you need new one(s)...
Quick test by just taping them up if that fixes it you can move on to silicone or epoxy etc...
note that the cracks are so small they can be hard to see...
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
    • Unless my sensor just died, was only a couple months old, I strongly believe it didn't. How can I test it? I never mentioned it being 20:1+?
