Rb25det (standard internals)
- Standard Injetors
- Standard AFM
- Stock Air box (K&N filter)
- GCG High flow OP6 housing
- Power FC
- Trust cooler
- Nismo Fuel reg
- Exhaust
- Bosch Pump
274.2 rwkw
Running 16 psi
Tuned by 'Femno' on a 2008 Dyno Dynamics
Running very safe AFR's
Opinions welcomed
Edited by DFAULT
  • Replies 58
Posted Images
there is something wrong there, you are getting 274 rwkw from the standard injectors and afm???
I have 210rwkw with the injectors frequently hitting 100% duty according to the pfc hand controller and the afm is tuned to 110% and still maxing out.
Well I know for a fact the standard injectors are capable of that power figure because Oblivion makes those figures on them.
But the AFM? I know for a fact the airflow required to make that hp is well and truly out of the scope of the standard AFM.
I'm sceptical but would be good to see some other 'more informative' graphs
DFAULT,
Which RB25DET is it?
What are the AFR's?
Great power result, I'm kinda tempted into keeping my 33 instead of getting a GT-R.
Cheers
Grant
p.s. is there a exhaust cam gears?
Edited by Count Grantleyish
What the........... That is amazing. Can somebody tell me why im only doing 233kws? on 17.5 psi
- full exhaust
- fmic
- pody
- z32
- 5 puk heavy duty clutch
- walbro
- 740cc injectors
- pfc
- ebc
- hyper gear highflow on stock turbo highflow
thats insane power mate!
- full exhaust
- fmic
- pody
- z32
- walbro
- 740cc injectors
- pfc
- ebc
What exhaust housing are you using, if its still the standard housing then that would be limiting you, you will get more with the op6 rear.
- full exhaust
- fmic
- pody
- z32
- walbro
- 740cc injectors
- pfc
- ebc
Geraus you have a different highflow so no comparison.
well i was the one that sold the turbo to danno and my car made 269.9rwkw and some ppl had doubt when i posted it up.
here are some more dyno graphs.
geraus - i have a back to back with your cars dyno result.
i 'scored' 230rwkw on a stock turbo, 12psi, stock injectors with stock reg, stock fuel pump, stock afm.
my point? high reading dynos are everywhere.
the important thing is a good tune, with good power delivery, etc etc.
1. You can tune past the AFM. Always have been able too.
2. Fuel reg is aftermarket, so the power can be made on stock injectors.
It's just too high compared to the rest of the world for 16psi IMO.
Not saying it's safe to do either of the above either ;)
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
