Rb25det (standard internals)
- Standard Injetors
- Standard AFM
- Stock Air box (K&N filter)
- GCG High flow OP6 housing
- Power FC
- Trust cooler
- Nismo Fuel reg
- Exhaust
- Bosch Pump
274.2 rwkw
Running 16 psi
Tuned by 'Femno' on a 2008 Dyno Dynamics
Running very safe AFR's
Opinions welcomed
Edited by DFAULT
  • Replies 58
Posted Images
there is something wrong there, you are getting 274 rwkw from the standard injectors and afm???
I have 210rwkw with the injectors frequently hitting 100% duty according to the pfc hand controller and the afm is tuned to 110% and still maxing out.
Well I know for a fact the standard injectors are capable of that power figure because Oblivion makes those figures on them.
But the AFM? I know for a fact the airflow required to make that hp is well and truly out of the scope of the standard AFM.
I'm sceptical but would be good to see some other 'more informative' graphs
DFAULT,
Which RB25DET is it?
What are the AFR's?
Great power result, I'm kinda tempted into keeping my 33 instead of getting a GT-R.
Cheers
Grant
p.s. is there a exhaust cam gears?
Edited by Count Grantleyish
What the........... That is amazing. Can somebody tell me why im only doing 233kws? on 17.5 psi
- full exhaust
- fmic
- pody
- z32
- 5 puk heavy duty clutch
- walbro
- 740cc injectors
- pfc
- ebc
- hyper gear highflow on stock turbo highflow
thats insane power mate!
- full exhaust
- fmic
- pody
- z32
- walbro
- 740cc injectors
- pfc
- ebc
What exhaust housing are you using, if its still the standard housing then that would be limiting you, you will get more with the op6 rear.
- full exhaust
- fmic
- pody
- z32
- walbro
- 740cc injectors
- pfc
- ebc
Geraus you have a different highflow so no comparison.
well i was the one that sold the turbo to danno and my car made 269.9rwkw and some ppl had doubt when i posted it up.
here are some more dyno graphs.
geraus - i have a back to back with your cars dyno result.
i 'scored' 230rwkw on a stock turbo, 12psi, stock injectors with stock reg, stock fuel pump, stock afm.
my point? high reading dynos are everywhere.
the important thing is a good tune, with good power delivery, etc etc.
1. You can tune past the AFM. Always have been able too.
2. Fuel reg is aftermarket, so the power can be made on stock injectors.
It's just too high compared to the rest of the world for 16psi IMO.
Not saying it's safe to do either of the above either ;)
    • Hey everyone, just wanted to let you know about an app I use to track the modifications, repairs, servicing etc I do to my R33 GTR. You might like to use it as well. I'm biased because my son just wrote and released it! But I think you might find it useful to... https://trackmymods.com
    • Hey everyone, been on here for a while, but never introduced myself before. 1st import was a R32 GTS Type M, then R33 GTS, now R33 GTR - each one sold to help pay for the next one. Over the years my son has seen me modify and do changes to my imports and was one of the reasons for him to build an app for car enthusiasts like us. (He can only afford a 2007 Honda at the moment, but he'll get there!) Anyway, bit of a proud Dad moment as he's released an app that I use and you all might like to as well. https://trackmymods.com
    • It will sound tragic and you wished you didn't have 1x exhaust per turbo. There's a reason why most S55 owners change to a single mid pipe.
    • Echo the comments about the well preserved condition it's in. It has the aero bumper too for extra points. Nice car, and please keep it like that! 🙂
    • 1. There are no real performance benefits. It sounds different, and as the pipes are not as large diameter you can claw back some undercar clearance or run lower (if that's your thing). 2. Twin pipes, offering exactly the same cross sectional area as a single pipe** will have higher pressure drop - so will not flow as well. That's because there is more surface area of wall per cross sectional pipe area, hence more frictional losses. ** But of course, it is almost impossible to get 2 pipes that are exactly the same XS area as a given typical single pipe. eg, 2x2" is not the same as 1x 3", although it is close. If the 2x pipes add up to less XS area than the single - it will just be flat out worse. If the 2x pipes add up to a bit more than the single, then it might come out as a wash. If the 2x pipes are substantially more XS area than the single, then it will probably flow a little better. 3. No. Why would there be? What have cats got to do with boost creep?*** ***But for f**ks' sake, please run a cat. 4. If you want.
