These are great, if you want an easy relatively cheap mod a chipped ECU is a good one.
there is a noticeable difference between the stock and MiNes computers. They are rare to make good use of the exchange rate and buy it!
Not sure if a NisTune board can go on one or not yet, but if it works you've pretty much got a fully unlocked ECU that'll work with your Auto.
you have to be careful wit these JDM ecu's, they are fine tuned to jap fuel which has a higher octane than what we have here in australia. you could find yourself getting some pre detonation(knock) running the same setup it was tuned for but on aussie fuel. personally i wouldn't touch any of those JDM chipped ecu's, there are better options available in australia.
p.s that ecu is a S1 ecu, year model 96-97, so its not a manual ecu.
  • 3 months later...
hey Guys
bought a S2 33 a few months ago fitted with a mines ECU, I havn't noticed any detonation, BUT I have to use 'top shelf' fuels otherwize I get a bit of hesitation, missing, backfire, generally a very unhappy car
on the upside I can tell which local servos have real clean tanks
I have a mines in mine which is pretty much stock in every other way. I find that it pings on small throttle applications so I have to retard it enough to get around the small throttle pinging instead of under load. The better the fuel the less trouble I have.
Mines looks like it has set up a english email support on its website. I haven't given them the details on my one yet but I will.
I believe they set them up for your application when they are first purchased. So they are set up for turbo A, cam B, etc
My old R32GTR had a Mines ECU, and I always use to run top fuel AND a bottle of Martini's octane boost with every fill up.
I still use octane boost with every fill on the Stag, but its a much smaller tank, so I only use half a bottle :P
Can get quite pricey though ....
Mind you if you have an safc and and sitc (which I do :D ) you might be able to get enough correction to get a good tune out of it. But I think I'd still rather do what tangles did and get a toshi chip made up, install that and then use the above mentioned to fine tune it. Would probably be cheaper too. I believe he got a pretty good result that way.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
