So yesterday I was picking my little sister up from work and on the trip home this cattle dog chases a plover right in front of me... Next thing I know I have collected a sign post and am surrounded in dust. Thank f**k we weren't injured at all!!
So now I am looking to get my baby repaired, but before I take it to a body work shop I would just like to ask you guys what you suspect is wrong (apart from panel damage) and what I should be looking at price wise for the repairs. Just ball park as I know each shop is different.
So here are some pictures and as you can see I collected the sign post right in line with the drivers side rear wheel. The wheel has moved in at the base, which the tow truck driver suggested is from the control arm being damaged. I drove the car up the driveway at home and didn't notice any obvious bumps and jumps as if the axle had been damaged though, but then again I am not mechanically minded so I wouldn't really know...
Any help would be appreciated.
Chris
post-61364-1256510876_thumb.jpg post-61364-1256510935_thumb.jpg post-61364-1256510987_thumb.jpg post-61364-1256511051_thumb.jpg
https://www.sau.com.au/forums/topic/293537-crashed-my-car-yesterday/
Looking at that control arm I would definitely be asking them to look at your subframe/chassis alignment mate. Its taken quite a hit there.
Noone here can give you even rough pricing unless they are involved in the accident repair bus. Take it to a couple of reputable repair shops and compare their notes.
Camerons bodyworks at Coopers Plains always seem to get a mention around here as being upfront and of a good standard when it comes to skylines.
I've had no first hand experience with them but it may be a good place to start.
Thanks for the input FineLine. Sounds like a good option but unfortunately I am up Townsville, probably should have mentioned that before sorry.
As for your suggestion that I could have subframe/chassis alignment issues, how complicated is repair in the worst case? Need to source replacement, or can these type of things be reworked??
Any body shop worth their salt will have chassis equipment mate. have a look around.
Looks ok. Just chuck in a arm and see what its like or You can just replace it with an adjustable lower arm off ebay and it does not matter if their is a alignment problem as you can adjust it out. Had the same damage on my old r32 and thats what I did
Thanks for the suggestion Brokenz. I just need to be as informed as I can be when I approach body shops and these inputs, solutions will help me heaps when I quiz the mechanics. So I will get some feedback from a few shops about the drivetrain (right word?? chassis) issue.
Can any panel beaters out there provide an estimate for a full rear quarter panel fix and respray?
... LOL would I have swerved if it wasn't on the road?? Now that I think of it, would it have been better to have hit the damn thing??
Ok so the old man knows a mobile mechanic at Cannington that is going to take a look at it on Saturday. So should I get hold of a control arm (found one for $225 delivered, is that reasonable?) so he has it on hand?
Better for you, but I'd take all necessary safe steps to miss someones dog personally. But then I'd also attempt to capture the dog or at least burn an image into my mind so the owner can pay.
    • Convert to dual filament bulb   FWIW, it will look odd - I dare say a bit dumb as it looks like your flasher relay has shit the bed.
    • If the RB20 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
