With the help of Allen (2LV8ETR), we chucked in my new (2nd hand) HKS EVC3 boost controller and it seems to be working fine. However I am having a few problems setting it up, does anyone have any experience with this unit? Anybody willing to help a brother out?
https://www.sau.com.au/forums/topic/293546-help/
1 tell us what model it is . or post a link to a picture os a similar one . or at least try to describe it
2 do a search . ALL of the original instructions are on the hks website
3 how can it seem to work fine if you have no idea how to use it ?
https://www.sau.com.au/forums/topic/293546-help/#findComment-4900298
1. As I said in the initial post its an HKS EVC3.
2. I have instructions however I cannot follow all the instructions.
3. All the buttons are working and it is able to read my boost levels but i am having trouble putting it into learn mode and setting my new desired boost levels.
https://www.sau.com.au/forums/topic/293546-help/#findComment-4900414
you cant add a boost controller into a R34 (rb25det Neo) without changing the computer. The stock computer doesnt allow it as I was told ages ago from some workshops. Well you can add one in but it wont do shit, wont adjust boost levels like what yours is doing now...so new computer it is
Edited by viet_boi
https://www.sau.com.au/forums/topic/293546-help/#findComment-4900544
Seems odd. Rob (don't know his username on here) has a black R34 with a manual boost controller and his is working running a stock computer. And those running Nistune still have their stock ECU's yet I have heard many have boosted them up. From what I've read you can add a boost controller however the ECU will just not allow you to run to large of pressures in them. Not calling b/s but my research has told me otherwise.
So very, VERY frustrating, argh! 5psi sucks!
https://www.sau.com.au/forums/topic/293546-help/#findComment-4900570
i'm not 100% sure about this. if you remove the stock boost controller. and just hook up your aftermarket ebc how will the stock ecu stop it from increase the boost.
I know it will to the typically add more fuel but i don't see how it can stop your from increasing the boost
https://www.sau.com.au/forums/topic/293546-help/#findComment-4901022
The OEM 2-stage boost controller is controlled by the ECU. You take the OEM unit out of the loop and install the EVC to the wastegate actuator and the ECU no longer has control over the boost levels. The EVC then takes control of the boost duties.
Once installed and switched on for the first time, the EVC is supposed to display a green highlighted "3" which depicts learning mode. It never went to that function. Trying to get it in learn mode was unsuccessful.
The issue is in the setting up of the unit, nothing else.
https://www.sau.com.au/forums/topic/293546-help/#findComment-4901057
i am unfamiliar with the hks unit, but is it possible to set it up without using the learn mode. just setting up the duty cycle, gain etc
https://www.sau.com.au/forums/topic/293546-help/#findComment-4901120
as my friends (Sean from Allstars and Ant from X-Speed) told me that with r34 you can't add a boost controller and turn it up like an r33 or 32 as the neo computer is designed differently, as viet_boi has said he is correct about the computer is the thing in the way that wont let you turn up the boost.
Nistune remaps the stock ecu...if your wanting to turn it up then i guess you'll need a updated computer (Apexi, Nistune, Vipec etc)
xx :D
https://www.sau.com.au/forums/topic/293546-help/#findComment-4901176
It is meant to be. There is a manual learning mode where you are meant to dial in the stock boost however this function didn't seem to work properly either, it seems the stock boost level was a lower number then what the unit would allow me to dial in  :ninja:
https://www.sau.com.au/forums/topic/293546-help/#findComment-4901344
xx :ninja:
again don't see how the ecu can stop you from turning up boost if you remove the stock boost controller and connect the ebc directly to the turbo wastegate actuator. then the ebc is controlling things.
Hank Scorpio; try this
http://www.hksusa.com/info/download.asp?id=1642#
or
http://www.rx7turbo.com/howto.htm
for some reason my pdf reader has f**ked itself and i cant open pdf
https://www.sau.com.au/forums/topic/293546-help/#findComment-4901700
Thanks man. I've got the instructions, they are just not being very helpful. I called JPC today to see if he might have any ideas or want to give it a shot and try, they didn't want anything to do to it! :banana:
Anybody living NOR and in the know wanna give me hand? I'm a nice guy! :) I tentatively booked it in with my mechanic on Wednesday to take a peak at it but like his Motech ECU's, he's expensive!
https://www.sau.com.au/forums/topic/293546-help/#findComment-4901796
Thanks man. I've got the instructions, they are just not being very helpful. I called JPC today to see if he might have any ideas or want to give it a shot and try, they didn't want anything to do to it! :)
Anybody living NOR and in the know wanna give me hand? I'm a nice guy! :P I tentatively booked it in with my mechanic on Wednesday to take a peak at it but like his Motech ECU's, he's expensive!
i try and look into it for you later tonight. i have setup a few ebc for myself and mates so i might be able to get something working but no promises :banana:
https://www.sau.com.au/forums/topic/293546-help/#findComment-4901871
I've tried going into manual mode but it says I have to put in my OEM boost level first which I couldn't be able to do, it wouldn't go low enough.
Perhaps I can reset the unit?
https://www.sau.com.au/forums/topic/293546-help/#findComment-4901989
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
