R33 Parts & Lots of them! :)
RB26 Engine - in good condition but needs some parts - $3000
RB26 Crank Shaft - $500
RB25 Sump - $120
R33 GTR Tail Shaft & Drive Shafts - $200 complete
R33 GTR V Spec Diff - $450
R33 Series I Front Bar including indicators - $150
R33 GTR Stainless Front Pipe - $150
R33 GTST Front Pipe - $100
RB26 Tomei Head Gasket - New in Box - $300
Greddy Type S Blow off Valve - $100
R33 Series I Steering wheels - $100
R33 Series 1.5 Airbag S/Wheel - $150
R33 GTR Transfet Case - $100
Set of R33 Series II Mats - $120
R33 Coil Overs Lowered - $150
R33 Coil Overs Standard - $150
R33 Standard Shocks - $100
R33 Standard Exhaust - $150
R33 Series I Grille - $80
R33 ABS Unit - $250
R33 Strut Brace - $60
R33 Cat removal pipes - $50
R33 GTST Standard Front Pipe -$20
R33 Standard intercooler - $50
R33 Standard Airbox - $100
4 x R33 Airpods - $30 each
R33 Rear Seat Belts - New in box $200
R33 Standard Springs - $50
R34 & Miscellaneous Parts.....
RB Adjustable Timing Gears - $100
Many Xenon Globes and Ballasts to suit Skylines - POA
3" Metal Cat with flanges - $150
Numerous Space Saver wheels - $50 each
R34 Polished Full Stainless Exhaust - on R34 GTR Vspec for 2 weeks - below cost $450
Apexi BOV - $100
RB20 Airflow Meter - $30
2 x 15mm bolt on wheel spacers - $50 pair
R34 Standard Shocks - $150
R34 Springs - $100
Exhaust Cutout valve - $50
S15 (magic) clear tail lights - $150
Call Chris on 0416 223437 for more details. Can courier anywhere in Australia
https://www.sau.com.au/forums/topic/293558-lots-of-r33-parts/
  • Replies 41
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
