FOR SALE: 1989 r32 gts4 skyline
Asking Price: $11000 neg
Killometer's: 115 000 km
Manual or Automatic transmission: Manual
Engine Type: RB20DET
Modifications: pretty stock exhaust pod H/D clutch
Road Worth Certificate: N/A
Registration: runs out this month but putting another 3 months on
Crash History: No Accident History - Inspection Welcome
Other Comment's about the vehicle: Bought the car at the start of the year very stock just neatened everything up put in a H/D clutch the other week new fuel pump went in today been serviced every 3-5000 using good oil and coolant had the attessa system flushed and filled with new oil when i had the clutch done and fresh G-box oil, had new front dump pipe fitted.
the car has never been boosted thats how stock it is bein the gts4 it full of extras ABS etc also has electric front lip which works :)
There is proble more i havent thought of love the car am a perfectionist with is as i was with my s12, just cant afford it as a first year auto elec :) there is nothin wrong with the car anything that needed doin i did and just in case you didnt know its a awd model has gtr drive line pretty much i can hook up a rwd switch if wanted .
pics can be found on the trader https://www.tradingpost.com.au/is-bin/INTER...3wAAAEjeZtpUjJq
Contact Details: 0430025163
cheers
Bill
https://www.sau.com.au/forums/topic/293569-r32-gts4-skyline/
PRICE DROP $10000
the car is perfect no rust no leaks runs very smooth no misfires and i think a good price im still keen on swaps for equal or lesser value car lookin for a sil80 180 or maybe s13
cheers
Bill
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
