FOR SALE: 1989 r32 gts4 skyline
Asking Price: $11000 neg
Killometer's: 115 000 km
Manual or Automatic transmission: Manual
Engine Type: RB20DET
Modifications: pretty stock exhaust pod H/D clutch
Road Worth Certificate: N/A
Registration: runs out this month but putting another 3 months on
Crash History: No Accident History - Inspection Welcome
Other Comment's about the vehicle: Bought the car at the start of the year very stock just neatened everything up put in a H/D clutch the other week new fuel pump went in today been serviced every 3-5000 using good oil and coolant had the attessa system flushed and filled with new oil when i had the clutch done and fresh G-box oil, had new front dump pipe fitted.
the car has never been boosted thats how stock it is bein the gts4 it full of extras ABS etc also has electric front lip which works :)
There is proble more i havent thought of love the car am a perfectionist with is as i was with my s12, just cant afford it as a first year auto elec :) there is nothin wrong with the car anything that needed doin i did and just in case you didnt know its a awd model has gtr drive line pretty much i can hook up a rwd switch if wanted .
pics can be found on the trader https://www.tradingpost.com.au/is-bin/INTER...3wAAAEjeZtpUjJq
Contact Details: 0430025163
cheers
Bill
https://www.sau.com.au/forums/topic/293569-r32-gts4-skyline/
PRICE DROP $10000
the car is perfect no rust no leaks runs very smooth no misfires and i think a good price im still keen on swaps for equal or lesser value car lookin for a sil80 180 or maybe s13
cheers
Bill
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
